Parasitic Drain cl-s 01
6th Gear
i have the car a while now and everything has been good up until recently. Something is draining my car's battery. https://acurazine.com/forums/images/smilies/whyme.gif I have checked all the relays and they are fine. I am thinking it could be the power locks because sometimes when i try to push them down manually they rebound right away. Now i have to unhook my battery cable when i know the car is going to sit in order to avoid high battery drain. HELP PLEASE!!! https://acurazine.com/forums/images/...s/thumbsup.gif
6th Gear
You could have gotten a bad battery... put a multimeter on your battery posts and start your motor. If the voltage drops below 10 volts the batteries bad or going bad. Battery should be charged or it should be right after a drive when doing this.
Pull the power door lock fuse if they're malfunctioning and that should tell you if it's in that circuit.
Smokeywater5 (12-04-2012)
MetalGearTypeS
08-29-2016 08:28 PM
RSpyder
09-30-2015 12:46 AM
