p1740 and p0305b codes on
I have an 2001 acura cl with 165 thousand miles, I recently had some transmission work done. Engine light turned on and these are the codes that popped up. Help with the causes to this pls!
You can find a page with all the trouble codes and what they mean here:
http://www.troublecodes.net/acura/32cl/
According to that, code P0305 means you have a misfire in cylinder 5, and P1740 is related to the Automatic Transmission (that's all it says). What kind of work did you have on your transmission? Replacement, or rebuild? If it was replaced, did you replace it with a new one or used one?
Any symptoms you've noticed along with the CEL and codes?
Jamus22
06-11-2023 10:08 AM
