New and need help with A/C
Hey guys and girls so I own a 2001 CL Type s and my ac has not been working for a couple months decided to fix it since hell has arrived where I’m at I switched out the low pressure hose and the receiver dryer but still have a major leak still I’m pretty sure it’s the compressor so my question is the 2001 odyssey compressor interchangeable with the CL?
Welcome to the forums.
Since this is a topic/technical issue which will require replies, and not a "New Member Introduction", this thread has been moved to the model specific forum.
FWIW: The Acura CL and Honda Odyssey A/C Compressor part numbers, don't match up, which is not unusual! That doesn't mean the Odyssey compressor won't work. I would compare the two, and see how they look, electrical connector, hose connectors, mount points, pulley, etc. If they all match up, and since, you already have the Odyssey compressor, I would try it!
Found the issue but still need help
So I found where my leak was coming from after switching out low pressure high pressure hoses the accumulator/dryer and now the compressor, I still couldn’t get vacuum and I had tried looking everywhere with black light and dye for a leak nothing today I bumped the powers Terri got reservoir and got green dye shooting out it was a hard line that was under the power steering reservoir and goes to the receiver dryer so my question is what is that line called it’s not flexible and I can’t find it if anyone knows where I can buy it Id appreciate it .
