Mounts
is planing PrisonBreak in
Mounts
any one have pictures of the mount locations on the car like where exactly rear mount is located and how to see if its broken. I hear a sound when i go over uneaven pavement or a hump or brake hard and it comes right about from the middle flor of the car. I just think its the rear mount because i got the other 2 replaced not that long ago.
but it could be something else. any suggestions.
ball joint? loose control arm?
umm yeah well i just had the alignmet done and it started couple of days after that, is it possible for that they didnt tighten them up right?
Try checking the front swaybar bushing. see if the bushings are worn or damaged. When I checked mine it was worn to a point it was touching the swaybar mount and I was also experiencing noise too. Instead of installing the stock bushing, I went with Energy bushings and that solved the noise problem.
Hey thanks YuuEmMaiMai, it was the loose control arm. Finally i was able to take it to the dealer and get it checked its been rainin like crazy in VA so they couldnt figure out wts wrong as it was all wet so they kept the car and gave me a rental for weekend, rental was sweet, a MDX fully with entertainment package, well they fixed the control arm and rotated the tires and did alingment for no cost so it wasn't so bad.
joflewbyu2
10-08-2015 11:16 AM
