Motor Mount Vacuum tube - Necessary?
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
So, my vacuum hose on the back motor mount was left out... it's a b%^& to get it in once the mount is installed bc you can't see it.
What is the function of the vacuum hose? Is it bad to not have it plugged in?
Whats up with RDX owners?
Its hooked up to a valve so when the engine torques it will stiffen it up. Id say yes it is important, especially since Ive been told it could cause a vacuum leak if it is left disconnected.
Ya, mine is disconnected too. I got under the car to change the tranny fluid and saw the line broke in two from the elements getting to it after all these years.
Not sure if there is an easy way to reconnect it without undoing all the mount bolts. I tried fitting my hand in there but had no luck.
Get it fixed
You wont need a new mount right away, but running without it connected for a long time could create excess wear on them.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
