Intermittent brake grinding
Noticed something these past couple days where occasionally it sounds like my driver's side front brake grinds intermittently when braking (regardless of light, moderate braking, etc). It sounds like it normally does after I give my car + wheels a good wash. However almost a full week afterwards, it still does it. Noticed it after I tried a new brand of spray-on/rinse-off wheel cleaner. Not sure if that makes any difference...
It doesn't happen every time I come to a stop, just.... sometimes. And the weird thing is that it's not a constant grinding, it's... well, intermittent. Instead of a constant grinding noise like KRRRRRRK, it's more like "KRRK......KRRK.....KRRK" Maybe some buildup or a spot on the rotors? Since it's intermittent and not constant, I'm thinking it's not worn-out pads or anything. Any ideas?
Another thing is that I can't really hear it so well if I roll down my windows. I hear it only inside the cabin, if that means anything.
Thanks for any help!
EDIT: Also my brake fluid is in need to be flushed/replaced within the next 2 months. Does that have any significance?
Brake fluid should have nothing to do the the sound you are hearing. I would not rely on the sensors to tell you about your brakes. It would be a good idea to take a look at the pads. Pull the wheel and see if there is still some brake pad left and that they are wearing consistently. That would be a good place to start.
Checked for gravel stuck in tread?
Pull off the wheel and check both inner and outer pads for wear. Also, there's an audible wear indicator that might be corroded or bent out of place...
Sorry for the not updating sooner.
Iunno, I had the brakes checked up (nothing really too in-depth, just a look-over) and everything is fine, apparently. The grinding noise did go away. tbh I just blasted the pad/caliper area and the noise just went away. Maybe just crap on the pads? I'll definitely keep an eye on it -- and all the things you guys mentioned
Now that my pads have been in for a long time, all four sets of pads and clips have started to rattle in the calipers, but that's a distinct sound of rattling when going over over rough road, not grinding...
