Help with my headlight bulb
My driver side headlight went out this late afternoon.
and when I turn on my normal headlight,,, the high beam indicator in the dash was fainted. (a little bit but not completely on)
when I switch to high beam, the indicator goes off...
anyone any clue what happened to my driver side headlight??
Thanks in advance
Sundance Gold in
There are 3 philips screws. Lose em up a little, twist the bulb and its out. No need to disconnect batt, just make sure lights are off -25kv is there you might get electricuted a little. If you want to be on safe side 2 20a fuses are in pass side under hood box. Have fun but mostlikely its ballast problem and that requires bumper removal!
