Help with Many fixes
It's about that time.... 80K... I need to replace several things:
- All belts - $?
- Alternator Pulley - OEM $53 (31141-P8F-A01)
- Engine mounts ~ $300
I'm thinking it'll be close to $1k? Is this normal? What advise would you give me?
Thanks for the help?
- All belts - $?
If you want all the belts replaced, the alternator tensioner, spark plugs, water pump, etc wait until the recommended 105,000 tune up cause with all of that its gonna be about $1,000-$1,200
Just replace the AC and the alternator belts for now. Wait for the 105k maintenance to replace the timing belt, water pump, and plugs. Why are you replacing the alt pulley for? Is it damaged?
SidhuSaaB
05-30-2020 12:40 AM
