Got code P0113 ?
Got code P0113 ?
As I pulled into my drive way cel came on.
I cleared,restarted the car with in 5 minutes so I pulled the code P0113 IAT sensor.
I have not bother locating and checking into it yet.
I assume it's the sensor in the rear of the manifold.
What symptoms would a bad IAT sensor cause.
Because at very light throttle while cruising it sounds like a misfire or slight spuddering .
Whats up with RDX owners?
IAT sensors are touchy. Sometimes they wont work right if you unplug them, sometimes they will.
make sure that the locking tab is not broken on the connector
Jamus22
06-11-2023 10:08 AM
