Gas Mileage Issues
Ok... So here's the deal... I just bought this '02 CL-S Auto w/ 74k on it. CLEAN as can be. I knew that I wasn't going to be getting the same mileage as my civic (32-38mpg) but I was hoping for at least 20. And so far it has gone something like this:
First tank: 17.4mpg 2nd tank (new plugs/air filter/cleaned EGR): 18.18mpg 3rd tank (raced it twice against my buddy's S60R and won 2x): 15.4mpg and this last tank was 17.8mpg I rarely go over 2500-3000 rpm driving daily in city & some interstate. I can't figure this out as my brother's Suburban is getting 17mpg and I'm driving a HONDA!!! I'm ordering NUMEROUS parts (Coil Overs, Wheels, Intake & TB Spacer, Pulleys, Headers, A "fat-cat" and custom exhaust) but if I can't get more mileage out of this now, I think there may be more serious issues than originally expected and don't want to dump a crap ton of money into it. Any ideas? I can't even find a part number for the fuel filter either? |
I get 15.9 city mpg w my new 4600 lb MDX.
I can get less if I drive it hard and fast or use less than 50 - 50 plus - premium mix. At 74K ... check how dirty intake system, & valves are. I had a sandblast clean done on my '02 Jeep at 60 K and got another mile per gallon. I think this meth/eth they put in really fowls it up. But note your range of repeatablity seems weird. You might want to check the repeatabilty of your odometer ... its prob not accurate either - see my post and link in mdx section. |
I only run Premium 92 - no ethonal
Originally Posted by dbramaged
(Post 12702428)
Prem is suppose to be 93/94 octane. Plus is 89/90 and reg is 86/87. |
Nebraska - 89 has 10% ethanol, but I run th 92 Octane that is not mixed. Regular being 87. I haven't run the race fuel yet (99 octane) but that will wait til the summer trip KCIR.
(Post 12702515)
The truth is you dont know what is in the tanks {could be Kat urine}. There is no 92 octane premium anywhere in the US and all winter mixes are less w alch eth or meth. You will get better w summer mixes and if you read whats posted on the pump you are naive. Extra octane is wasted octane !! |
Originally Posted by EL_PIC
(Post 12702460)
I dont know what state you are in but most states use like 10 - 15 % meth eth in their winter mix at pump.
(Post 12702515)
(Post 12702967)
You need to check it more ...
The truth is you dont know what is in the tanks {could be Kat urine}. There is no 92 octane premium anywhere in the US and all winter mixes are less w alch eth or meth. You will get better w summer mixes and if you read whats posted on the pump you are naive. Extra octane is wasted octane !! OP - Check the catalytic converter. Do an oil change. Its possible the valves are out of spec too. What brand fuel are you running? How noisy is the engine at idle? What plugs did you buy? Whats the condition of the O2 sensor? If possible, try to get your AFR values. Point blank, your mileage sucks. If you are truly driving it easy and getting less the 20mpgs, something is clearly wrong. I have a built motor and when I beat the crap out of it I cant get anything lower then 22mpgs. |
Drive slower on the freeway. I drive 60 mph and get about 23 mixed. I also have intake, headers and exhaust so that helps but the biggest deal is highway speed and city driving.
Originally Posted by aznboi2424
(Post 12705152)
In the city i got 16-18 mpg thats normal i just dont care about it anymore. 24-26 hwy depends on how i drive. But i wish i could see 20-22 in city and 28-30 on hwy.
(Post 12704676)
How do you know its not mixed? Does the sign specifically say only regular unleaded is mixed?
87 Regular Unleaded 89 w/10% Ethanol 92(sometimes 91) Premium Unleaded I was saying regular & premium aren't mixed with Ethanol
(Post 12704676)
any other ideas? |
What brand of O2 sensor ?
(Post 12702967)
Originally Posted by StreetKA
(Post 12707499)
Our ECU dont like Bosch O2 sensor but im not sure if that possible.
(Post 12707743)
Get a Denso sensor. Im surprised you havent thrown a CEL yet. |
I used to be the kind of person that believed that all brands of gas are the same as long as you are using the same octane until I switched to Shell. Prior to using shell I used to get 16-18 miles per gallon city driving and since I get 20-23 city driving also my car feels more power. I'm not saying that Shell is the only gas that will do this but it does point out that not all gas is created equal.:2cents:
^I have to agree i always used exxon because was the nearest one but then i switched to shell and everytime i use it i get like 20-30 miles more from a tank.
I'm still waiting on more tune up type parts, but did find out that the original tank had 89+10% ethanol mix from the dealer and think there is still some of this mixed into the tank as I'm only running it down to 1/3 tank before refilling. I'm going to run this tank bone dry and fill up on some good gas.
Originally Posted by clpassenubye
(Post 12709092)
(Post 12709244)
(Post 12713867)
Not me I find that going to Chevron or shell I was only getting 240 to a tank, now that I'm going to Costco, Sams clubs I'm getting 250-260 a tank, sometimes I get 245 but thats when I push it, but I still need to do an Oil Change Air filter Spark plugs and work on my solenoid
(Post 12714471)
That is totally contrary to what I found. I went to Costco for several months and my car lost power it was really noticeable when I stopped going there this issue went away. I can't comment on Sams club though.
Every Costco gets its fuel from different suppliers. Luckily, the Costco I go to gets good gas.
Turns out, it was the injectors. I pulled them over the weekend and had my brother (the technician) test them and they weren't "misting" but were "squirting". He tried to clean them, but unfortunately, it was a lost cause. Bought new ones and installed them. Put 170 miles on it over the weekend and not even to a half tank yet. I think the gas mileage will finally be where it should be.
24 mpg... seems to be fixed!
How many miles on car ?
Edit: 74k and already bad injectors ? Weird isnt ? |
(Post 12729546)
thats good I should inspect mine then 171 and not @ half a tank yet.. :thumbsup:
So injector cleaner didnt help ? You bought a set of new ones or just one ? No matter how easy im on the gas cant get more than 140miles on first half of the tank. Sometimes less. I drive mostly in the city
After my valve adjustment 2 months ago, I am getting roughly 340 city miles per tank, and just this past weekend I took a roadtrip to Daytona...Halfway on the fuel gauge my trip odometer read 212, so thats roughly 425 highway miles per tank.
I have Intake and headers. |
(Post 12729921)
Originally Posted by ANC297
(Post 12729949)
Another reason to use top tier gas and regular fuel system treatments or seafoam.
I'm sure everyone's injectors arent in tip top shape especially with CLs now reaching 100k+ miles compared to new injectors. |
Any DIY on checking the injectors ?
<---Winner:
http://i23.photobucket.com/albums/b3...IMAG0047-2.jpg No top offs, odometer was reset at fillup. That was a trip from VA to NY last summer and the a/c was on the entire way. IIRC it was about 280miles at the half way mark. |
thats good..
and Gary that top tier gas stuff is BS like I said I get better MPG at Sams club then I did at Chevron and shell |
W t f ? Best i got lately was about 25mpg on the way to great falls meet 5 weeks ago. It was like 220miles on the tank
No DIY, my brother handles all the tech stuff like that. The dealership has access to runners and signal relays to run the injectors outside the car. I'm a desk jockey, my brother is the technician. ;)
I'm going to try to pull mine out and look at them hopefully it isnt to hard
(Post 12730548)
