Fml engine locked up
OIL FILTER ADAPTER GASKET BLEW FIRST I WAS REALLY IN A JAM HAD NO MONEY NO OIL DROVE IT A WHOLE DAY WITHOUT OIL THEN HAD THE GASKET REPLACED AFTER IT WAS REPLACED THE DAMAGE WAS DONE ALREADY THE ENGINE LOCKED UP THE NEXT DAY SMH ANYWAY CAR HAS 247xxx AND WOULD U GUYS THINK ITS WORTH IT TO REPLACE WHOLE ENGINE?
THINGS IVE DONE SINCE 245xxx: |
[QUOTE=Jerm Thompson;15931021]OIL FILTER ADAPTER GASKET BLEW FIRST I WAS REALLY IN A JAM HAD NO MONEY NO OIL DROVE IT A WHOLE DAY WITHOUT OIL THEN HAD THE GASKET REPLACED AFTER IT WAS REPLACED THE DAMAGE WAS DONE ALREADY THE ENGINE LOCKED UP THE NEXT DAY SMH ANYWAY CAR HAS 247xxx AND WOULD U GUYS THINK ITS WORTH IT TO REPLACE WHOLE ENGINE?
THINGS IVE DONE SINCE 245xxx: Alternator Battery Timing belt/water pump Valve cover gasket/spark tube seals Spark plugs Oil filter housing gasket |
depends how much you like the car, at that mileage, its not really worth it unless you like it. BUT you can swap a j35a3 in for less than 500$. all your j32 parts will swap over and save you money.
Driving a car knowingly with no oil?! :nono: you killed it.. Look for a used engine to throw in
I'm surprised the engine even lasted that long, to be honest.
:rip: |
And what is an oil filter adapter gasket? You mean the actual oil filter failed? What brand of filter were you using?
I guess I do still hear something new everyday. |
(Post 15931119)
Originally Posted by 03-6/6
(Post 15931094)
There's No such thing as an 04-06 type S.. type S came in 07-08 for the 3rd gen TLs
(Post 15931094)
(Post 15931094)
(Post 15932064)
J35A3 is a direct fit if you're automatic. You don't want the newer style engine like the 04+.
Originally Posted by Jerm Thompson
(Post 15932054)
The peice that the oil filter screws into also the oil pressure switch and vtec solenoid screws into is known as the oil filter housing or adapter theres three bolts that attach to block in between the block and oil filter housing is a gasket with compartments and a screen well it failed
I have no idea what you're talking about, to be honest. I've never noticed what you're saying, and I've never heard of anyone else suffering a failure of that nature. Something isn't adding up, but regardless... |
(Post 15932677)
what? The vtec solenoid is no where near the oil filter.
I have no idea what you're talking about, to be honest. I've never noticed what you're saying, and I've never heard of anyone else suffering a failure of that nature. Something isn't adding up, but regardless... i think he's talking about #14 here |
01-02' MDX = J35A3
Literally a DIRECT BOLT IN. Easily found for less than $500. PS.. Run on sentences are fuckin mind numbing… :snipe: |
so are broken caps lock keyboards
Dang, would've been cheaper to take the day off work, or grab a taxi.. Anyway, compared to the cost of a new car, its a TRUCK LOAD of money cheaper to swap in the J35 motor. Especially since you already know the car and where its been.
Some lessons are learned the hard way... and this is one of them.... Type S engine are not totally common so J35A3 swap is best bet
