Flasher Relay - Where is it located?
I'm trying to locate the flasher relay in my 2001 Acura 3.2CL Type-S.
The turn signals and hazard flashers only blink one or two times and then quit. All of the lights on the car work and fuses are fine. I'm guessing it's the flasher relay. I looked in the fuse panel inside the car on the drivers side and I also checked the relay box under the hood on the passenger side. I couldn't find the flasher relay in either location. Does anyone know where I can find it?
Thanks,
Brian
Thanks,
Brian
Found it
I called the Acura dealership in Omaha and they gave me the answer. The Flasher Relay is above the kickpanel, under the dash on the driver's side. There are three relays there. It's the bottom one.
Thanks,
Brian
Thanks,
Brian
Steven Maslauskas Jr. (10-16-2023)
MetalGearTypeS
08-29-2016 08:28 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
