F-ing headlights!!!!!
I have a 2001 Acura CL-S and the right headlight went out last night. first it was really dim and then it eventually went out. the left one is starting to flicker and i cant lose both of them. I havent checked the fuse so ill do that tomorrow..any suggestions before i have to blow money on godamn headlights?
Says the guy who put black caliper paint as a mod in his sig.
Rotora slotted rotors|H2 Ceramic Pads|Legend Coupe front calipers|Black caliper paint|XS headers|M5 lip spoiler|Yokohama Ice Guard IG20|Tokico HP Shocks|H&R Sport 51858|Corsport shifter cable bushings|CDD bypass|Techna-fit SS clutch line|UR underdrive crank pulley|Innovative poly engine mounts|Progress TL rear sway bar|Energy sway bushings|MOOG swaybar endlinks|NEUSPEED short shift|TL-S shift knob|TL rear console vents| Hella micro de fogs,TL fog switch|HIR hi-beam conversion|Homelink mod
You can test your headlights at an Acura dealership, if you're close to one. If your headlight doesn't light up in the Acura tester, it's probably your ballast.
If it's your ballast, it's going to cost you. They're $420 each from the dealership. Check out my other post on this issue for directions on how to change the ballast.
AmplifiedDetails
09-24-2015 02:55 PM
