Check engine light...Whats this code???
I got the codes run and it said it was the auxiliary emission control. the code is
P1456
Any one know exactly what this is..???
Thanks in advance!
P1456
Thanks in advance!
The exact code is....
Evaporative Emission Control System Leak Detected (Fuel Tank System)
The manual goes into a whole procedure to test the system out, but It's likely a bad gas cap, or Bad purge valve.
I got the same code when my purge valve died. Not just ticking, but it was stuck in open loop & would not close.
Received 1,080 Likes
First thing first. Remove the gas cap then put it back on and tighten it till it starts clicking. I would disconnect the neg battery terminal for a few minutes. Then check to see if the CEL comes back. More often than not it's just the gas cap not being screwed on tight enough.
Cost = $0
Cost = $0
Billu99tl
09-13-2015 11:30 AM
HeloDown
09-08-2015 06:51 PM
