Cars electrical shuts off completely
'01 Acura CL Type-S
So over the last few days when I get in my car after it has been sitting for at least 2 hours I start it up fine and drive to my destination and once I switch the car off into standby the headlights would both cut out then back on....
Now tonight I got home from work and was checking to see if the lights would do it once again, but to my surprise the car basically shut of as if it was a transformer that lost its Spark.....
I sat there like wtf just happened, after about 10 seconds the car came back to life.
Anyone have a clue on what this might be?
Bad battery(1 year old)
Bad alternator
Other worse electrical problems
Bad alternator
Whats up with RDX owners?
Sounds like a ground issue to me.
'01 Acura CL Type-S
Well my dad called Allstate and they told me to bring back to the shop that did my work after my accident in October, but I doubt work that was done nearly 5 months ago would be the cause of the problem
But i'm taking it in on Friday
'01 Acura CL Type-S
So the shop that did the work after the accident said they found nothing wrong with the work they did (as if they would) and said they heard a knocking in the engine and said they think the car is losing oil pressure
Now would the car losing oil pressure result in the car shutting down electricity, if any thing that's just an added problem to me
No it wouldnt cause any electrical issues. What was damaged in the accident?
'01 Acura CL Type-S
The accident minor to mid level front end damage like the hood passenger side light housing and front bumper...
Now when I just picked the car up they say it sounds like the engine has a bad valves or cylinders
'01 Acura CL Type-S
Also when i'm driving and come to a stop it feels as though the car is sometimes having trouble responding like it is on the verge of shutting down, would that mean it could be a tranny problem
I checked the tranny fluid a few mins a go and it was reddish with no odor
Sounds like a possible IACV issue regarding the shutting down issue.
What tests did they run to determine a bad cylinder or valves?
'01 Acura CL Type-S
Is that an expensive fix (more than $1000)
I can't even really take their word for it because they are solely a body shop that doesn't do mechanic work
But I do hear a knocking sound in the engine while it runs
The part itself is $100, but you can get away with just cleaning it. Replacing it takes at most an hour, its mounted to the bottom of the throttle body with two screws.
'01 Acura CL Type-S
So now my car is back on the road but now my speakers emit a humming sound when the volume is up at halfway
Does this mean my speakers are blown or the possibility that to much power might be going to them?
OEM radio or aftermarket? Sounds like you might have a ground loop. Does the noise fluctuate with engine speed?
'01 Acura CL Type-S
To my knowledge it's a complete stock system, but at some points when I accelerate the speakers sound like they are squealing or a very high pitch sound at first I thought it was my tranny and I said you have to be kidding me....
But for some reason I thought to turn off the speakers and the sound stopped, I was going to replace the speakers but didn't want to if when I plugged them in they would blow and $300 would be gone.
How would I check for this loop
Unregistered Member
This. It is not any of the other issues discussed so far. It is definitely just a problem with the wiring. My car did the exact same thing every now and then. Replace your ground cables.
If there's a mechanical problem with the engine, it wouldn't kill the entire power to the car. This is an electrical problem.
It's not the alternator, and it's most likely not the battery. If it was one of these two, it wouldn't just come back to life 10 seconds later.
Your speaker problem is pretty weird, so it might be a deeper problem with the electrical system. Still, I'd be willing to bet the fix is the $20 ground cables. Replace them, clean your positive terminals, and tighten both terminals down pat. This is a cheap fix, but just hard to find the exact problem.
A ground loop sounds exactly as you described. Its a high pitched whine thats dependent on the engine speed and doesnt occur when the radio is off (no power to the amp/speakers).
Mine started to do it recently, and Im running the stock speakers, only an aftermarket headunit, line output convertor, and a sub. Ive not yet gotten around to swapping out the speakers.
'01 Acura CL Type-S
So the amplifier is in the trunk under all the carpet behind the backseats?
As in this photo
https://www.acuraoemparts.com/delray...3s3m01_b16.png
Also do I have to replace the amp as well, because that's about another $350 FML
And thanks for all the help guys I really appreciate it
As in this photo
I think its mounted to the decklid.
Derp. I meant rear deck
'01 Acura CL Type-S
Well now after the car sits off then I get into it after about 2 hours or so the speakers works about 80% correctly with the bass hitting and all speakers going
Oakes
Wash & Wax
10-12-2015 11:17 AM
