Car making alot of noise when accelerating like vib5rating tin can...
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
So I get my car back from getting the tranny installed wensday and it seems fine. Today when accelerating making really annoying noise at certain RPM.s Im guessing its my headers resonating. Its only when accelerating from slower speeds and when it gets to HWY speed no more sounds, but when acceleation its like im draging metal. when nutral or park not really any noise only when accelerating.. I had headers put in months ago w/no noise, when taking out a tranny do u gotta dissconect anything to do with the headers..
I hope it something where i dont have to spend any $$ cuz this car is sucking me DRY!!!NOW!!!![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Quarantuning
The down-pipe doesn't have to come out to do the job. But its in the way of everything.
The whole sub-frame "cradle" underneath the down-pipe that connects the suspension and the trans itself, axels, starter etc. all have to come out. I bet they saw your new headers and figured the down-pipe would come out real easy. So they may have taken it off to save some time. However if they left it on I guarantee it got bumped around, knocked, leaned on etc... That may be the case![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
I used to see these replaced on a daily basis when I worked at an Acura dealer in 05(parts dept). Back then it was in the middle of a full blown recall, warranty nightmare. CL, TL, MDX all the same crap. There were 2 guys who all they did everyday was transmission R&R. I logged them in and out and scheduled pick up and delivery, so they passed through my hands too. We were making a killing on those and Honda got the bill. Crazy! But nobody was complaining because everybody had work.
B A N N E D
So I should call the guy that did my tranny?
So since I had my headers put in
Months ago with no noise and all of a Sudden 100 miles after my tranny gets rebuilt it making lots of noise when accelerating! My tranny guy prob just did not tighten everything up enough? I gotta go back to him and hope he fixes it!
Any other ideas on whAt it can be and if this is def it?
headers seem to hit in two places
front crossmember under the radiator check the j pipe clearance
if it has been vibrating you will see the wear spot on the weld line and on the header
j bend in the oilpan where the cat joins
make sure its not bouncing on your oil pan
could just be a loose heat shield on the cat if he decided to break the headers off
B A N N E D
Im hoping its just the heat sheild , When I installed My headers one of the nutz broke off so i left one off, so that might be the problem, the tech said it might make noise in the futurs and the tranny people maybee messed something up of moved something.. If i take off the heat sheild would that be bad, or it really would not make a difference!
B A N N E D
Yeah It sounds like its comming from down there, But only when moving and a certain RPM,s its like vibrating metalic noise...REALLY ANNOYING.. worste then a civic w/fartpipe at certain RPM's ... So the heatshield basically serves no purpose? It is not there to protect the Cat from rocks being kicked up?
Regional Coordinator (Texas)
does it sound like single tin can layer vibrating or multiple tin can layers?
i dont believe it has anything to do with the tranny.
i dont have any heat shield on my headers either.
B A N N E D
I know it's not the tranny but I think when they took the traany out or put it In they messed something up. They say they don't take out the downpipe but it started happening after they rebuilt the tranny. I know it's not the tranny just what they did when they reinstalled the tranny
B A N N E D
not the headers but the J-pipe is in the way u can drop the tranny w/o removing it but the could have moved something or maybee even too the J-pipe off cuz it was so new and was easier to drop the tranny with the j-pipe off, i dunno.
all i know for 6 months after the headers where installed no noise, no 3 days after tranny gets rebuilt there is noise from that area.
Whats up with RDX owners?
Climb under and look while someone revs the car.
Missing My CL-S
like civic said. jack up the car, if you need to, and check the heat shield (after the car has cooled). my heat shield was rattling like hell especially stopped at a red light or on a hill. i took it off last year.
hopefully it is the heat shield b/c it's an easy fix and won't cost you anything. good luck man
try what civic said. I had that noise before. I thought it was heatshield.
so i took'em out, but noise was still there. getting louder louder... so i jacked my car up and climb under the car while my friend was revving up. it was cat. man that noise was f#$king annoying me! so i just replaced RT cat.
I hope yours is just heatshield.
when my car did this i had a bad flex pipe ... i blame motor mounts and around same time cat went bad ... could have been peices of the cat rattling around
B A N N E D
The noise went away.
After driving through a monsoon in NJ yesterday it seems the noise went away.??
It was wierd cuz in park reving no noise.
In nuetral reving no noise..
Just when driving and a certain RPM's at like 25-35 MPH it was annoying and very load but when i got up to HWY speed no noise..
But today on the way to work no noise.. prob just the heat shield will take it off next oils change!
Hey guys,
I have the same rattle vibration sound at around 2000 rpm. Mostly in 3rd, 4th and 5th gears. A low cheap sound rattle.
So when you say remove the heat shield do you mean all of that tin heat shield above the entire exhaust system, or just the heat shield around the cat. Because I removed the one around the cat and I still have the sound.
B A N N E D
Hey guys,
B A N N E D
Cats do go bad... My inspection is not due for anouther 7-8 months so I will replace it if it fails inspection..If not I will just live with it, like i said if the radio is on then I hear nothing so I will just keep the radio on!
I just rev a little higher and when I shift into 4th and 5th it never goes below 2000. I never hear it this way. Doesn't seem to affect gas mileage that much.
Mike Bertram
09-10-2015 09:27 AM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
