Auxiliary Input Converter (Blitzsafe)
Ok another question and the search function is not providding me with results...
My clock stopped appearing on my navigation screen after the install, any ideas?
Also, I bought a PIE aux converter for sound, the blitzsafe was not available at local shops...anyways, it does not work. Please tell me if there is an aux converter that works for my car (2001 CL w/ Nav, obviously, it has the BOSE in-dash 6-disc changer). Is there more to the install? All I did was reach behind it and plug into the empty port. Do you have to reset the radio or anything else? The PIE model I bought sppeared it would work with applications listed in package, but nothing when hooked up to PS2.
Please let me know about installation procedure for the aux converter. Should I just return the PIE model and order a Blitzsafe or another brand.
Veterans out there, I need your help.
Also, picture quality is related to wire used. First time around bought 24 AWG wire and picture sucked!!! Did it all over again with 16 AWG wire. I'm retarded...
Hope someone can help...
as far as i know, the navi does not have anything to do with the radio in the sense of making the clock not appear. Are you sure that the clock is not in the small box at the right of the screen on the bottom?
navtool.com
31
11-16-2015 08:30 PM
