alignment specs, excessive passenger castor
Old 04-22-2016, 11:27 AM
AcuraCls6speed's Avatar
Is it something I should be concerned about? 3.4 left 4.2 right
Attached Thumbnails alignment specs, excessive passenger castor-20160422_112111.jpg
Old 04-25-2016, 03:09 PM
Lone Wolf
brian6speed's Avatar
I would say yes. Caster should be about positive 3 on both sides. It isn't Adjustable unless you shim radius Rods or get custom parts made or find offset bushings that fit.
Check the right side suspension arms and see if anything is bent.
Old 05-01-2016, 12:21 AM
03 tls nc's Avatar
If your caster is off than you more than likely have worn out radius rod bushing, bent LCA, or knuckle, and/or bad ball joints. I had a bent LCA that caused my caster to be out enough that the car turned completely different in each direction and was not noticeable holding the new control arm beside the bent one.
Old 05-02-2016, 10:30 PM
I recently changed the radius rod bushings all 4 of them. It seems they were pulled to far forward. maybe they will set it. the reason I changed them was because I hit a giant pot hold and it busted the nut off the radius rod and stripped the threads. I installed a new radius rod and all 4 bushings. Maybe when torqueing them down I pulled them to far forward.
Old 05-04-2016, 12:47 PM
Lone Wolf
If I remember correctly the bushings are different sizes and need to be installed in specific order/placement. That might be your issue.
2 are one size and other 2 are different. You probably have longer 2 on same side and shorter 2 on other.
Old 05-05-2016, 02:22 AM
I installed them right and made sure but maybe I'm blind. I'll check that though. If not I'm thinking shims or subframe shift
Old 05-09-2016, 03:04 PM
Lone Wolf
You can't always trust ppl doing alignments to use machines properly.
I went in for an alignment last week and when handed paper wondered why my caster was listed as 2.1 and 2.4. Went back today to get it re-adjusted from a different tech and readings were 2.8 this time.
Still think yours might be related to hitting pothole and bending something though.
