7 - 8 lb S/C Pulley
Since I have swapped at j35a3 in my CL last year after I blew my j32a2 with the supercharger I am looking to get the 7 - 8 lb pulley but I am having a hard time finding the part number for it so I can purchase it. I have the high boost pulley on the supercharger now which produced 4.5 - 5 lbs with the j32a2. Correct me if I'm wrong but with that same pulley isn't it going to be a little less boost on the bigger displacement j35a3? That's why I want to get a 7 - 8 lb pulley.
Here is a 4 rib 3.12" pulley I found for you back in Jan2017 from summit racing when you were asking a similar question:
https://www.summitracing.com/parts/vor-2a034-312 Then Marcelechka chimed in with the comment below recommending a 3.2" pulley based on his personal experience.
Originally Posted by Marcelechka
(Post 15942994)
3.12" is pushing it.
Terry from SFLP recommended making me the 3.2" pulley based on my configuration at the time. Had to gain what was lost due to plumbing... 3.275" alt + 3.2" blower shaft will net 10 to 12lbs without an intercooler. As mentioned before, you'll need bigger injectors & a method to tune. Heat soak will also be an issue (specially in FL) as the blower is operating well beyond it's efficiency range to be effective. :explode: https://acurazine.com/forums/2g-cl-problems-fixes-70/serious-help-needed-949436/page6/ It should help refresh your memory and help you decide. It just might turn out to be a 'grand experiment', in regards to which size to get for the PSI you are looking for because of the added displacement of the J35A3 vs a J32A2.. Hopefully, Karanx7 with chime in with the pulley configuration he is running with his M60 on a J35A3. :dunno: :) :thumbsup: |
Thank you Zeta! Yes, I remember that I had talked about this subject awhile ago. My hbp is 3.33" (stamped right on the s/c Pulley) and my alternator pulley is 3". I think I'm going to purchase the one you mentioned (3.12"), only because I don't think that S/C can support much more than that. Also don't want to blow it up again. Lol
On a different note, has anyone had any luck with the AEM EMS 30-6051 working with the manual harness? Researching online all I've found was that boomslang makes a jumper harness that works but has some issues with certain things. |
I used Pulley Boys Comptech 4 Groove Keyed Pulley 3.2" diameter. I was just tuned last month, we saw 8lbs on the dyno with that pulley.
Here's the link: https://pulleyboys.com/cart/comptech...category_id=21 |
Originally Posted by 2ndgentl
(Post 16349946)
Originally Posted by bluedc2
(Post 16350724)
Here's the link: https://pulleyboys.com/cart/comptech...category_id=21 And that schematic looks to have the information 2ndgentl needs to get his AEM EMS 30-6051 up and running. :wish: Very informative post. :thumbsup: |
Holy shit Bluedc2!!! Thanks a lot for passing all that info, very much appreciated!!! Are you running a J32 or J35, because 8 lbs of psi is around where I'd like to be. Also, what kind of power were you making at 8 psi?
(Post 16350774)
Originally Posted by zeta
(Post 16350770)
Nice find on the pulleys bluedc2.
(Post 16350782)
My CL has a JDM J32a on 7lbs it made 320hp and 290tq BUT my clutch was slipping BAD on the dyno so I’m sure it would have made more. Glad the diagram could help! |
(Post 16350785)
Forgot to add, the pulley location is on the supercharger shaft. Oh and my name is Chris. Lol |
(Post 16350724)
the 'Base 3.0" alternator pulley' OR the 'High Boost 3.275" alternator pulley' To get to the 7-8psi with the pulley boy 3.2" S/C'er shaft pulley? :) I'm thinking you have the 'base alt. 3.0" pulley because Marcelechka claims he achieved 10-12psi with a 3.2' S/C'er pulley using the HBP Alt. 3.275" pulley noted above without the FMI. |
(Post 16350801)
Just to clarify, Chris, are you utilizing:
I wonder if I should either get the 3.0" or the 3.12" since I have a J35. Im thinking the 3.12" will give me 7-8 psi?
(Post 16350790)
Thank you Chris! 320 hp and 290 tq @ 7psi with a slipping clutch isn't bad at all!! Sucks that you have to do a clutch job real soon though. Do you have a clutch in mind that you're going to use? Also, are you running the stock flywheel or aluminum? I need to hurry up and just get my car dyno'd now so I can have a before and after the S/C results. - Joe
Ive dumped thousands into this car fixing his mistakes and finally now 3 months ago getting the car runing right, hense why I sent Dezod AEM. I blew my first motor after finally purchasing the Dezod kit, THR CAR WAS ON THE DYNO! And the motor went. I wasn’t surprised though, it was never running right (I purchased it supercharged with HBP) since I purchased it. That’s explain why I have a JDM J32a now I purchased from HMOtrs w/ 50k miles. She’s strong as a rock now! |
(Post 16350822)
(Post 16350826)
Joe, I have OEM flywheel that was actually just installed 6 months ago. So long story short, I purchased the car with a ASSCO light weight flywheel (car reved much fast but I hated the over rev in betwen shifts) and a CEL light for the crank shaft position sensor. Thinking flywheel was the cause I put a brand new OEM one in. Turned out it wasn’t the flywheel, it was because the previous owner put a j35 reluctor wheel instead of J32. The previous owner also lied and said he put a new clutch in the car and obviously that’s not true as a year later it’s slipping already. So when I had the flywheel done I didn’t even thing to change the clutch because I though I was new. 🤦🏾♂️ Ive dumped thousands into this car fixing his mistakes and finally now 3 months ago getting the car runing right, hense why I sent Dezod AEM. I blew my first motor after finally purchasing the Dezod kit, THR CAR WAS ON THE DYNO! And the motor went. I wasn’t surprised though, it was never running right (I purchased it supercharged with HBP) since I purchased it. That’s explain why I have a JDM J32a now I purchased from HMOtrs w/ 50k miles. She’s strong as a rock now! |
(Post 16350828)
So the previous owner of my CL had a j35 in it before and was running HBP and when he put a J32 back in before I purchased it was still reading 5lbs. If that helps you any, I’m thinking it will all be the same. |
(Post 16350832)
Damn, sounds like you've had a lot of sleepless nights with that CL, but glad you moved forward with it and got everything resolved! I love seeing people still interested in these CL's after knowing there's hundreds of other cars out there to choose from. That must of been hard to see your engine blow as it was getting dyno tuned...
(Post 16350837)
I had the HBP (3.33") on my j32a2 and it was producing 5 lbs of boost. Ended up blowing my engine (didn't get it tuned soon enough). I went through two j32a2 engines from the junkyard and both were bad (one had a cracked block, and the other had low compression). That is why I ended up with a j35a3. Did you purchase your jumper harness through boomslang or Dezod? I just want to make sure I get the same setup as yours. I can't wait to hear that whine again...
All the Dezod kit is a AEM box switched to hall sensors and the Boomslang harness.
(Post 16350826)
Just an FYI, Chris. You may already know this or have it already installed on your car. There is a Mugen fan switch and low temp thermostat modification that turns on the fans sooner to get things cooler. From what I understand, with this mod, you don't 'gain' any power per se; however, it keeps you from 'loosing power' when stopped or in slow moving traffic. :shrug: It will affect the cabin heat function, slightly, in colder climes, so be aware. The part numbers are below IF you don't already have them installed and are interested: THERMOSTAT 19301-XGMR-0000 FAN SWITCH 37760-XK5-00N0 RADIATOR CAP 19045-XGER-0000 Furthermore, if you or Joe need to replace or upgrade your OEM radiator to an aluminum one there are options which are discussed on the thread below: https://acurazine.com/forums/second-...pgrade-960326/ :thumbsup: |
(Post 16350870)
Dam, that sounds like a nightmare. I'm sitting here thinking why would the previous owner think that a 'timing belt drive pulley with reluctor' from an automatic engine, either J35 or J32, would have worked on a manual transmission CL-S configuration. :ugh: The part numbers for the automatic '02 J35 TB drive pulley' is the same as the automatic '01-03 J32 TB drive pulley'. So, that means you / your mechanic had to hunt down the cause, the wrong TB drive pulley, and then purchase the correct one to eliminate the CEL.:whyme: By that time, unbeknownst to you, the engine may have already been damaged, in some way, to cause it to 'grenade' on the dyno after being fixed with the proper 6-speed TB drive pulley.
(Post 16350861)
https://cimg2.ibsrv.net/gimg/acurazi...ddab2145be.png |
Not sure what I'm looking at in the red circle:
https://cimg0.ibsrv.net/gimg/acurazi...66e8af41ac.png |
(Post 16350870)
That's the 'Connector A' 'Connector B' 'Connector E' box diagram illustrated in the middle of the schematic supplied by Chris in post #6 above. |
(Post 16350880)
Is this the kit I need? Also, I already have the AEM EMS SERIES 2 30-6051, do I let the tuner switch the box to hall sensors or is that as easy as it sounds? I see a smaller box attached to your green harness, not sure what that is. Sorry for all the questions, but things that really interest me is like my caffeine in the morning. I get excited when I learn new things. Lol
(Post 16350857)
I love these cars! This is the 4th I’ve owned in 6 years of that tells you anything. Haha! |
(Post 16350887)
That harness is for a AEM FIC not AEMD EMS. The black piece you see is what the CL harness plugs into.
1) make a copy of the schematic Chris provided in post #6 2) contact Boomslang directly and talk to them about making you a 'harness' compatible to the AEM 30-6051 to 2001-2003 Acura CL MT based on the schematic provided. 3) cross your fingers and toes that they agree; otherwise, they may not agree because that 'harness' may be proprietary to Dezod :( |
(Post 16350890)
2ndgentl, this is what I would do:
(Post 16350890)
(Post 16350896)
Thanks Zeta, I will contact them this week and cross all fingers and toes. Worse case scenario I will contact Dezod (I have him on my FB messenger and had talked to him before) and ask him if he could make me that harness.
If Dezod refuses to make ONLY the harness for you, for whatever reason. Technically, since you have the schematic, if you can source all the appropriate connectors, wiring and the box the CL harness connects into, you could make one yourself. Sourcing that 'stuff' online should not be that hard and readily available. You will have to follow the schematic and 'pin' the wires to their appropriate connector location. It will just take time and patience. Then of course, there is the matter of switching the AEM EMS 30-6051 box to hall sensors, which should not be to difficult, although opening the box will probably void any warranty. :shrug: Good Luck! |
Nice Chris.:) |
(Post 16350904)
https://cimg7.ibsrv.net/gimg/acurazi...4e6688fb12.png
https://cimg0.ibsrv.net/gimg/acurazi...f72773b5a1.png |
(Post 16350911)
Wow Chris, a million thanks! I feel like you have held my hand guiding me through the light. Lol Should I just personally message him and go from there? I wonder if I should also ask him how to switch the AEM box to hall sensors
(Post 16350911)
(Post 16350944)
2ndgentl, if you find out how to do this, on your AEM EMS 30-6051 unit, make sure to take plenty of pictures and show us what exactly you did. It would be a first here on the forum. :thumbsup:
