02 Acura CL type S (speed cluster not reading mph & miles?)
Need a little help, my speedometer stop reading miles per hour and mileage. I recently changed the wheel speed sensor on the driver side ,also the transmission speed sensor next to the refill transmission Bolt... I purchased a used cluster and swapped it out but still nothing? This may sound dumb but is there a fuse to the cluster? Also I don't have traction control or cruise control due too (mph not reading it's speed) do I have a wire issue or a break in the Wire? Thank you for your time,I didn't check if the speed cluster on the mph Gage is sending power through the connections...will do so but need help....
