StreetKA's CLS6 Thread
Old 03-11-2012, 02:35 PM
  #1281
In search of excitement
kingofdust's Avatar
Do you think anyone would mind if I wasn't in my Acura but my friends Lexus?
Old 03-11-2012, 02:36 PM
  #1282
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,136 Likes on 4,805 Posts
Old 03-11-2012, 04:10 PM
  #1283
kingofdust's Avatar
hhahah Morgan I gotta work with what I can!!
Old 03-11-2012, 04:30 PM
  #1284
StreetKA's Avatar
No CL no care. You better bring it with you
The following 2 users liked this post by StreetKA:
civicdrivr (03-11-2012), kingofdust (03-11-2012)
Old 03-11-2012, 05:00 PM
  #1285
kingofdust's Avatar
y'all are ruthless! I love it
Old 03-14-2012, 04:05 PM
  #1286
StreetKA's Avatar
so it was great meeting you Morgan again that was a good meet...
thanks to kingofdust for not coming and not letting us know...
finally pulled the trigger to order the brakes... EBC rotors with EBC redstuff pads just the front though
civicdrivr (03-14-2012)
Old 03-14-2012, 05:40 PM
  #1287
civicdrivr's Avatar
I made the drive all the way from VA for that meet!!
Good seeing you again man. I cant wait to see Jays car with the new mods
Old 03-14-2012, 06:00 PM
  #1288
kingofdust's Avatar
Hhaha brother I'm really sorry, I got pulled to stand watch at the last minute and had to stay at campus! It's bull but I wasn't trying to get restriction for missing. my fault! I don't even have my car down here yet, March 27th will be my first meet!! Hope to see you there!
Old 03-17-2012, 08:17 PM
  #1289
StreetKA's Avatar
another axle bites dust this time GSP with aprox 5k miles on it maybe less
Old 03-17-2012, 09:30 PM
  #1290
Received 1,732 Likes on 1,390 Posts
Depending on the mileage and while you have that half shaft assembly off the car, it might be a good time to change the bearing and seal.
Old 03-17-2012, 09:31 PM
  #1291
kingofdust's Avatar
Sorry to hear that brother!
Old 03-18-2012, 12:00 PM
  #1292
Lone Wolf
brian6speed's Avatar
Hmm. Did that axle have the damper on it? Looks like I might have to pony up for oem axles.
Old 03-18-2012, 01:25 PM
  #1293
StreetKA's Avatar
Nope this one was without damper. I would wait and get the custom GB axles. Not worth to spent $1600 on oem axles... Even dealer doesnt put them on they are too expensive... They use aftermarket ones.
Old 03-18-2012, 01:27 PM
  #1294
StreetKA's Avatar
Bearing maybe next time i take it out but seal? There is no oil and im not sure whats the seal for
Old 03-18-2012, 02:20 PM
  #1295
In your pic below, it looks like that heavy black border sitting in the circumference of the metal bearing support.
#24 on the link below:
http://www.acuraoemparts.com/delray/...All&vinsrch=no
I wonder if those axle shafts were cast in China.
Old 03-18-2012, 02:35 PM
  #1296
civicdrivr's Avatar
Definitely a manufacturing defect. I cant wait to get those DSS axles.
Old 03-18-2012, 03:44 PM
  #1297
StreetKA's Avatar
It broke like it was made out of wood
Old 03-18-2012, 04:02 PM
  #1298
03 CLS-6
1foxbody's Avatar
X2
Old 03-18-2012, 06:52 PM
  #1299
civicdrivr's Avatar
PlayDough is more like it. Even when I drilled into it to pull it out, you could tell it was very soft.
Old 03-29-2012, 08:03 PM
  #1300
StreetKA's Avatar
so today i noticed when i shut off the car it dies differently like there is something wrong... you do some work on the car you'll notice if something acts a bit different...
right after i shut it off i could hear like there was a little air leak somewhere so i start checking where is it coming from and its coming from the oil dip stick... looks like PCV valve is clogged or broken.
Has anyone ever replace their valve ? not sure where is it located right now... should i get new one or just clean it and put it back ?
ok i think i forgot what it was PCV valve but now i know and it doesnt seem to be clogged...
Old 03-29-2012, 08:07 PM
  #1301
civicdrivr's Avatar
The PCV? Rear valve cover, its that little 90* shitty piece of plastic coming out of it.
Old 03-29-2012, 09:02 PM
  #1302
StreetKA, when you had the intermediate half shaft assembly out of your car recently, did the shaft as it enters the bearing housing have any play/slack to it?
I replaced the half shaft (it was the original OEM w/131K) on my car yesterday and it had a sh*t load of rotational play to it. This occurred when holding the bearing housing against a flat surface and then performing a circular movement of the shaft without actually turning it in the bearing housing.
Compared to the new one, the old one was really bad. It (the play) was not noticeable while on the car because of the fixed shaft mounting in the tranny and to the block. However, when it was removed it was significant.
Old 03-29-2012, 09:08 PM
  #1303
StreetKA's Avatar
TBH i didnt check that but that might an issue for us too...
now im tryin to figure out if thats PCV valve that is the issue or is it piston rings
Old 03-29-2012, 09:36 PM
  #1304
OK, thanks, I was just wondering.
Hopefully it is not piston rings.
IMHO, If you replace the PCV, go OEM over aftermarket for best results.
Old 03-29-2012, 09:39 PM
  #1305
civicdrivr's Avatar
I might pick up a new one when the DSS axles come in just for added security. My car has almost 156k miles on it, and 100k of those are with me at the helm.
It better not be another fucking ring
And definitely go OEM on the valve, they dont cost a whole lot.
Old 03-29-2012, 09:50 PM
  #1306
I've been chasing a clicking noise that I hear as I go at a constant speed. It is especially noticeable while going through enclosed parking garages. This was the last thing on my list, so, now I'm pretty convinced it may be my diff bearings.
Anyways, purchase the whole assembly P# 44500-S87-A00 rather than messing with replacing the bearing, it's alot simpler. The part # is the same for the 98-02 V6 Accord, so you can save a few bucks getting it from Honda over Acura.
civicdrivr (03-29-2012)
Old 03-29-2012, 10:21 PM
  #1307
civicdrivr's Avatar
I get all my parts from Honda anyway, Ive got friends that usually get me the parts for cost.
Old 04-08-2012, 08:39 PM
  #1308
StreetKA's Avatar
its not a pcv valve i think... its something else i swaped the pcv from the old engine and it does the same... im gonna order new one just to make sure its not that...
Old 04-09-2012, 10:48 PM
  #1309
Regional Coordinator (Texas)
nspec_ya4's Avatar
damn that sucks! u might as well start carrying extra axles with you and all the tools needed to replace them!
Old 04-10-2012, 11:10 PM
  #1310
civicdrivr's Avatar
Sad but true
Old 04-11-2012, 08:34 AM
  #1311
StreetKA's Avatar
That was a plan lol but now im really trying to take it easy on the car.
Old 04-12-2012, 10:16 AM
  #1312
StreetKA's Avatar
Its not a pcv...
Old 04-13-2012, 07:58 PM
  #1313
Any luck with the problem you are running into?
You can hear air pressure releasing from the oil dip stick tube at engine shutoff?
Is it enough pressure to actually push the fully inserted oil dip stick up and out of the oil level pipe?
Old 04-13-2012, 08:53 PM
  #1314
StreetKA's Avatar
no its not but i was trying to track it down and it was annoying me but it doesnt seem like its something serious since the pcv valve is new and fully functional...
i will make a video of it tomorrow
zeta (04-13-2012)
Old 04-13-2012, 09:44 PM
  #1315
I understand.
BTW, talking about annoying sounds, when you had your tranny rebuilt, did it or the carrier bearings make any noises out of the ordinary that alerted you to them being worn while driving the car?
Thanks.
Old 04-14-2012, 10:30 AM
  #1316
StreetKA's Avatar
Tbh i think the differential bearings were fine... The counter shaft were shot though. I just replaced to be safe.
Im getting some vibrations lately after i replaced rotors and balanced my wheels i think its an axle... Which has 5k miles tops
zeta (04-14-2012)
Old 04-14-2012, 04:58 PM
  #1317
civicdrivr's Avatar
Yea, mine are vibrating too. I was going to replace them again last weekend but decided to just hold out for the DSS axles.
Old 04-18-2012, 12:05 PM
  #1318
StreetKA's Avatar
So finally i found the time to fix the tranny leak.
It was leaking from behind the tranny mount bracket. The cap was leaking
So i ordered new oring for this cap and once i got it i decided to go ahead and replace it.
What i found out is that we do have an oil filter in 6mt tranny which is located behind that cap
So i took the cap a closer look, removed the oring which looked fine to see this.
There was like hair line crack all around the oring which was the reason why i was leaking oil. I have freaking idea how did it broke... I can speculate about it but personaly i never touched that and to my knowledge no one did.
Luckily i still have a spare tranny in my garage so i could use the cap from it and i will order new cap probably today. I just cant imagine how could this thing crack like this.
Anyway no more leaks and everything is fine.
Old 04-18-2012, 12:42 PM
  #1319
3.5 psi
gnuts's Avatar
that's pretty random! you must be relieved though.
Old 04-18-2012, 12:51 PM
  #1320
Interesting find StreetKA. That's the first time on this forum that I can say I have seen that part.
In the Helms' exploded view-transmission housing diagram, the manual has that part labeled as 'Oil Pump Strainer'. In this case the 'oil' is the tranny fluid.
Flange bolt
Strainer cover
O-ring
Strainer set spring
Oil pump strainer
Quick Reply: StreetKA's CLS6 Thread
