StreetKA's CLS6 Thread
Old 03-03-2012, 01:10 PM
  #1241
StreetKA's Avatar
Originally Posted by zeta
What did your tranny rebuild consist of?
New Differential/bearings, seals, gears etc.
Thanks.
Countershaft bearings, differential bearings, seals, and dowel(?) springs.
But countershaft bearings were completly shot.
zeta (03-03-2012)
Old 03-03-2012, 06:08 PM
  #1242
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,132 Likes on 4,803 Posts
Old 03-03-2012, 06:20 PM
  #1243
StreetKA's Avatar
It runs oil change now and test drive and then party lol.
Old 03-03-2012, 06:45 PM
  #1244
anthracitecl's Avatar
Congrats man!!!
Old 03-03-2012, 09:06 PM
  #1245
StreetKA's Avatar
O gosh i cant wait till tomorrow to drive it. Its runs great. Everything seems to be the way it supposed to. I had few problems but it should be fine.
Old 03-03-2012, 09:13 PM
  #1246
reese8789's Avatar
Congrats man. Did you change the timing belt and water pump on the motor?
Old 03-03-2012, 09:18 PM
  #1247
civicdrivr's Avatar
Why cant you drive it now? You know you want to.
Old 03-04-2012, 04:16 AM
  #1248
StreetKA's Avatar
Timing belt all the pulleys water pump termostat. Cant remember what else.
I had to go to work 6am
Old 03-04-2012, 06:22 AM
  #1249
StreetKA's Avatar
I found out that my fuel pressure regulator is leaking
Old 03-04-2012, 07:03 AM
  #1250
bigdaddyKA8's Avatar
Congrats! I guess this is another reason I haven't installed many of my parts besides just be a lazy ass! Bone stock the car is still a blast to drive! Doing incremental upgrades lets you enjoy them. Anyhow glad to hear you'll be back in the road. FPR should be a breeze given the circumstances!
Old 03-04-2012, 09:33 AM
  #1251
StreetKA's Avatar
I need picture really quick of how fuel lines connects to the stock fuel pressure regulator by the firewall. I need to see how the washers are positioned.
Old 03-04-2012, 06:40 PM
  #1252
StreetKA's Avatar
P0300, P0303, P0304, P1399
i had fuel leak today and i had to make a temporary washers to seal it i just hope thats what it is now because they may block some fuel going through
BTW those are exact same codes i had before engine swap - interesting right ?
other than that car is running fine... i think im still leaking some coolant on one of the hoses but i will look at that tomorrow
there is a difference between a coolant lines from 6MT and 5AT also i had to close some of the fittings (or bypass it but its good for now)
Old 03-05-2012, 07:15 PM
  #1253
StreetKA's Avatar
i did the compression test today to begin with and its all good... i feel better now lol...
Old 03-05-2012, 08:44 PM
  #1254
Received 1,731 Likes on 1,389 Posts
That is a bit strange. The engine harness for all the electric connections to the new auto engine is still from the original six speed engine, correct?
Old 03-05-2012, 09:18 PM
  #1255
StreetKA's Avatar
everything is original 6speed except for the engine i swaped out everything... so there is new EGR valve runners and IM(cleaned) new coilpacks and spark plugs.
today when i put everything back together after compression test i started the engine and it was misfiring and what i found was the plug for the coilpack on the cylinder #1 didnt sit right i moved it and it went back to normal kinda weird but i took electric contact cleaner and sprayed all the connectors... i will see tomorrow if that made any difference
Old 03-05-2012, 09:44 PM
  #1256
lol, I'm sure you have probably been over EVERYTHING with a fine tooth comb by now.
The only thing I was going to suggest; however, I'm not sure if it would help your misfire issues, was to check the wire harness modifications that were done for the S/C'er install at the MAP/TP sensors and IACV plugs, for kinks, pinches, cuts etc. I remember you said at one point that you found wires at the ECU/ECM loose and had them fixed, so it maybe worth a recheck, if you had not already done so now that the blower is history.
In addition, in regards to the 'plug for the coilpack', check to see that the embeded female ends have all of the metal contact sleeves present. Maybe one has broken off and has fallen out, thus not allowing full contact with the male side on the coilpack, IIRC. Also good to check those wires for kinks, pinches and cuts as well.
My guess is something is up with the wire harness because that is the only thing you have not replaced.
Hate to see you go through all that work and still have to deal with those pesky codes, lol.
Old 03-05-2012, 09:54 PM
  #1257
mugen_kid's Avatar
Damn awesome thread and car, looks like you have a lot of time into the CL!
Old 03-06-2012, 09:31 AM
  #1258
StreetKA's Avatar
I loled when read the codes i was like wtf this is not happening again, is it ? And i decided to start with compression test and all of the cylinders were around 125-130psi
Old 03-06-2012, 07:50 PM
  #1259
StreetKA's Avatar
thanks man i did spend alot of time to learn on my own how to do stuff it took me alot of sweat and blood but it was well worth it...
i realized that the only thing left on the car that has something to do with old engine is injectors so i ordered set of these and hopefully will pick them up tomorrow or thursday... seriously WTF i cant believe that im still fighting this issue... i think the 3.5 plans are on hold i need to really think about what i want to do...
Old 03-06-2012, 08:38 PM
  #1260
3.7L Nitrous Breathing CL
richardparker's Avatar
Am I missing something here or did you miss type your psi #'s ?
Did you mean 225-230 ?
Old 03-06-2012, 09:04 PM
  #1261
StreetKA's Avatar
there is two ways (that i know of) to check the compression on each of the cylinders
1. remove all the spark plugs, screw in the gauge and crank it for only one resolution (one spike) and stop repeat it 3-5 times on each of the cylinders. anything below 115-120 psi is too low
2. remove one spark plug at the time and screw the gauge in and crank it for 5 seconds on each of the cylinders
i believe that the first one is more accurate and this is what i learn actually from Paul
when you find out that the one of cylinders is down on the numbers you can check simply if its a piston ring or valve or HG by adding a bit of oil lets say 10ml to that cylinder and repeat the test. if the pressure goes back to where its supposed to be that means you have a bad piston ring if its not then its a valve or hg
Old 03-07-2012, 09:16 PM
  #1262
StreetKA's Avatar
Bad news. I gave up fighting with this car and droped of the car to Jae. Car ran bad today and alot of weird stuff is happening like the coilpack plugs poping out by itself out of nowhere... I drove the car to his shop and i thought that im not gonna make it. All i know as of now thats its not coils or spark plugs or either injectors... Im prepared for worse which is... Idk... lol
Old 03-07-2012, 09:24 PM
  #1263
In search of excitement
kingofdust's Avatar
Hope all goes well street! Fingers crossed on cheap repairs!
Quick question you going to the sti vs evo shootout in englishtown this weekend?
Old 03-08-2012, 04:04 AM
  #1264
StreetKA's Avatar
I wanted to but first there will be way too many cars and my car isnt running good
Old 03-08-2012, 03:09 PM
  #1265
civicdrivr's Avatar
Old 03-08-2012, 05:08 PM
  #1266
mugen_kid's Avatar
Good luck man, let us know what you find out. Not that you wouldnt lol
Old 03-08-2012, 05:38 PM
  #1267
StreetKA's Avatar
I didnt drive it much but car feels awesome. Engine timing was messed. It was my fault i think i got lost with all this mess with engine swap and i did it wrong. I dont care car is fixed and runs te way it should. Pulls hard
Old 03-08-2012, 05:49 PM
  #1268
Some people confuse the timming marks on the pulleys too.
Some think the thicker marks that that are used to see threw the peak hole are the one's you use but,the thin ones on the teeth themselfs are the marks you use.
Or if you dont bring all timing belt slack all the way to the tensioner the after some rotations it will change timming as well.
Glad to hear it up again.
You have been taking me on a rollor coaster ride if your going to stay here or dump the car.
I can only imagine your stress level over the last couple months.
Old 03-08-2012, 07:30 PM
  #1269
3.5 psi
gnuts's Avatar
nice to have you back!
Old 03-08-2012, 07:46 PM
  #1270
03 acura cl type s
rush's Avatar
So you keeping her ?
Old 03-08-2012, 07:51 PM
  #1271
Again
Old 03-08-2012, 08:04 PM
  #1272
StreetKA's Avatar
lol.
i didnt say or no yet
Old 03-09-2012, 07:29 AM
  #1273
StreetKA's Avatar
I may actually go because of my friend that wants to race me. This time he is gonna win though.
Why ? You want to race me to ?
Old 03-09-2012, 01:27 PM
  #1274
civicdrivr's Avatar
So........
You keeping it?
Old 03-09-2012, 01:52 PM
  #1275
StreetKA's Avatar
Let's see how she is gonna treat me from now on.
Old 03-11-2012, 10:53 AM
  #1276
StreetKA's Avatar
I need new brakes. Im broke in between EBC ultimax with ebc redstuff pads and stoptech kit from xlr8 website. I think stoptech is better but what do u guys think ?
On the side note my transmission is leaking oil from the bottom case seal according to Jae. I will take care of that this week.
Old 03-11-2012, 01:58 PM
  #1277
kingofdust's Avatar
Haha your a clown buddy, and nah no need to race anyone, just wondering if your car was going to be there today but I didn't even end up going so its cool.
Old 03-11-2012, 02:05 PM
  #1278
StreetKA's Avatar
I was just messing with you. I didnt go either.
Old 03-11-2012, 02:09 PM
  #1279
kingofdust's Avatar
Yeah lol I had to get you back! Im going to try and come out to one of the mall meets asap!
Old 03-11-2012, 02:31 PM
  #1280
StreetKA's Avatar
Try to make it to this meet this tuesday.
Quick Reply: StreetKA's CLS6 Thread
