StreetKA's CLS6 Thread
Old 02-02-2012, 08:33 AM
  #1161
shifting at 7k
azeezp13's Avatar
wow that's hawt!
Old 02-02-2012, 09:59 AM
  #1162
3.7L Nitrous Breathing CL
richardparker's Avatar
Looks like some polishing progress on the mani.
Be careful when you tighten down the manifold cover mine paint splintered like little chips all along the botom edge.
Old 02-02-2012, 09:37 PM
  #1163
StreetKA's Avatar
no progress i just made it shine a little bit, made the surface smooth but still cant match the blower
waxed the car. this shit is good
Old 02-02-2012, 09:41 PM
  #1164
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,140 Likes on 4,807 Posts
Check out the chrome powdercoat. It might be the finish you're after.
Old 02-02-2012, 09:47 PM
  #1165
StreetKA's Avatar
i would have to powdercoat the sc too but i dont like the color you said its too shiny polished aluminum is what im looking for
im just trying to find a place where i can drop it off
Old 02-02-2012, 10:01 PM
  #1166
civicdrivr's Avatar
What are you doing about the s/c'er?
Old 02-02-2012, 10:02 PM
  #1167
StreetKA's Avatar
waiting for my tax impatiently lol and sending it to Magnuson or Paul not sure yet
Old 02-06-2012, 08:30 PM
  #1168
StreetKA's Avatar
im having worse and worse thoughts about whats going on with my car now... its annoying really... tomorrow i will install few more parts if that doesnt help i will be MAD
Old 02-06-2012, 08:50 PM
  #1169
civicdrivr's Avatar
What now?
Old 02-06-2012, 08:52 PM
  #1170
03 acura cl type s
rush's Avatar
What's wrong with it now ?
Old 02-06-2012, 08:57 PM
  #1171
03 CLS-6
1foxbody's Avatar
x2 I hope you get everything worked out!
Old 02-07-2012, 04:29 AM
  #1172
StreetKA's Avatar
Engine is hesitant at times to accelerate it vibrates but not always and thats the only thing that makes me think its not internal problem. Im having acura tech take a look at it and download the live data. Im affraid that i may have bent valve or something but basicly i never overrev the engine and the compression test is good. Keep your fingers crossed.
Old 02-07-2012, 07:13 AM
  #1173
03 acura cl type s
rush's Avatar
^ are you coming to the meet today ?
Old 02-07-2012, 08:33 AM
  #1174
StreetKA's Avatar
Yes
Old 02-09-2012, 09:01 PM
  #1175
StreetKA's Avatar
New oem EGR Valve installed and EGR port cleaned, New oem injectors installed, New Denso Primary sensor installed, Brand new set of oem coilpacks installed, new set of spark plugs installed... i did just a few miles but i can feel the hesitation is there and it runs rough STILL and P1399... next step is to recheck again grounds and probably move the battery back to the front but i doesnt make sense to me because nobody on this board had issues like that after battery relocation...
next step is to get Acura tech to do the valve adjustment i will have one of the guys come to my house and do it for me...
i dont know whats next if that doesnt help seriously... i just want to fix this problem i dumped like $800 just in parts this week...
  #1176
StreetKA's Avatar
all the blood and sweat for nothing... i even got curb cleaner into my eye yesterday... fuck that
ABS light came on... my mechanic jammed the speed sensor wire when pulled the knuckle for ball joint replacement wire is broken and i need new sensor
Old 02-09-2012, 09:27 PM
  #1177
Received 1,733 Likes on 1,390 Posts
OEM plugs or ik22's ?
Old 02-09-2012, 09:49 PM
  #1178
Do a leak down test before anything else.
Old 02-09-2012, 09:51 PM
  #1179
Street, since all of the coilpacks and plugs are new, could there possibly be a short or loose connection at the connector to the coil pack(s)?
Maybe a closer inspection of the wires coming out of those connectors might reveal something? Just a thought, while I was looking at the manual.
StreetKA (02-10-2012)
Old 02-09-2012, 11:10 PM
  #1180
Boosted...
WBA-01's Avatar
When you cleaned the egr port, did you make sure to do the 6 individual ports at each runner(red in picture), also a quick check for out of adjustment valves is a look at your map reading. With the engine warmed up and at idle your map should read about .86v to .88v. if it's higher than that its a good indication that valves are out adjustment.
Old 02-10-2012, 04:13 AM
  #1181
StreetKA's Avatar
Oem spark plugs. Compression is good so i dont see reason to do the leak down test. I will check the connections once again. But its not that. When i first started it was running nice then it started same freaking thing. All gaskets are new from the head to the top cover plate and i made sure they are installed correctly Vacuum leak ? I dont think so but i will check that. Map sesnor voltage i will check that once i get my hands on live data scanner. I dont think its a valves either because thw problem is not constant but who knows. Fuel ? I dont think so i ony fill up at shell and exxon and only 93.
Yeah guys keep the ideas coming.
Old 02-10-2012, 08:40 AM
  #1182
Just so you know.
If you have good compression numbers that does not mean you will have the same results with a leak down test.
Some mechanics choose to do a leak down even before a compression test.
Anything from a cracked piston,blown landing,valve stem seals,valve adjustment,worn cam lobes ,cracked sleeve,block or head,etc. can cause a misfire too.
And since you have covered most the fuel and spark componets to fix the problem with no luck it would not hurt to check your leak down percentage's.
Old 02-10-2012, 10:26 PM
  #1183
StreetKA's Avatar
finally some progress...
i did few extra grounds in the engine bay but that didnt make much of an difference also i found that my MAP sensor wiring by ECU where you split the wire for ESM install wasnt best shape i took care of that and engine is running nicely and smooth...
im still getting the p1399 but at least car is running way better.
im probably getting someone to do my valve adjustment again just for shits and giggles to have that piece of mind...
Old 02-10-2012, 11:01 PM
  #1184
Good to hear,
Old 02-11-2012, 02:08 AM
  #1185
civicdrivr's Avatar
Old 02-11-2012, 06:45 PM
  #1186
StreetKA's Avatar
i feel like im gonna go and do the valves now i want to get back on road with SC so freaking bad !!
next week im taking a trip to drop off the blower at Paul's and possibly with civicdrivr head to Henry to pick up some parts :P
Old 02-12-2012, 07:44 PM
  #1187
StreetKA's Avatar
again it starts doing the same it was fine for few days and it basicly same thing...
i will do valve adjustment tomorrow and replace the fuel pump for the walbro 255 one (one that came with sc)
leakdown test is coming next but im lost now it might be internal damage but the car sometimes runs better sometimes it gets worse if that would be internal damage it would be constant right... maybe its faulty MAP sensor or WHO THE FUCK KNOWs what else...
im getting on the edge already when i want to fix it or get rid of it
Old 02-12-2012, 10:08 PM
  #1188
civicdrivr's Avatar
Deep breath man. Hang in there. Youll find the issue soon enough. Worst case scenario, you have a spare motor to drop in
Old 02-13-2012, 06:37 AM
  #1189
StreetKA's Avatar
I dont like what you just said. Is there "no thanks" button ?
Seriously im tired i want this car to be running good. Cant wait to do leakdown test
civicdrivr (02-13-2012)
Old 02-13-2012, 05:23 PM
  #1190
civicdrivr's Avatar
Sorry
Old 02-13-2012, 10:02 PM
  #1191
StreetKA's Avatar
i did the valve adjustment today... valves were tight and i adjust them to be on the loose side... i can hear them ticking now louder but im still getting flashing cel... no solid cel yet though
here is what i installed
Old 02-14-2012, 01:17 AM
  #1192
Regional Coordinator (Texas)
nspec_ya4's Avatar
that looks cool!
Old 02-14-2012, 12:18 PM
  #1193
Wide Body 3.2 CL-S
krazykrnboi's Avatar
oooo i like... can you still see it with the covers and manifold on?
Old 02-14-2012, 12:31 PM
  #1194
StreetKA's Avatar
Yes you can but i still haven't finish polishing the other intake manifold and i have old one which is black. I dont like the way it looks and thats why i didnt post it yet.
Old 02-14-2012, 12:51 PM
  #1195
Wide Body 3.2 CL-S
icic... looking good though.
Old 02-14-2012, 12:58 PM
  #1196
StreetKA's Avatar
Ok screw it. Here it is.
Old 02-14-2012, 01:20 PM
  #1197
Wide Body 3.2 CL-S
LOL oooo nice
Looks good!!!
Old 02-14-2012, 03:41 PM
  #1198
Baller of Uni
CLassy02's Avatar
Nice. Paint looks good. How'd you do it?
Old 02-14-2012, 05:26 PM
  #1199
civicdrivr's Avatar
Old 02-15-2012, 09:15 PM
  #1200
StreetKA's Avatar
Dont praise the day before the sunset - they say
I noticed that my AFR was a bit too high at wot so i decided to replace the stock fuel pump for the walbro 255 the one that came with supercharger and car ran perfectly for about 50-60 miles then started to do same thing and its running bad. Its driveable but something is
not right. I doubt its internal problem. I can feel loss of tq in low rpms. No codes except the flashing p1399.
Im going to take a trip to Paul tomorrow morning i hope he's gonna find the problem.
Quick Reply: StreetKA's CLS6 Thread
