Show CLS with Racing Hart/RH Evo C2's
Beware of leakage
Any of you have this setup, if yes please share, looking to get. Thanks
Beware of leakage
Originally Posted by Silverbulit40
They are 18s and yes they are RH EVOs
Beware of leakage
As long as you didn't get bigger brakes you should be ok with a 3mm spacer. Thats what i had. You won't clear it without the spacer.
I know the term spacer = create more space, but how ?
Enjoy the Ride
its pretty much a piece of aluminum that is shaped like the hub and goes on like your rims go on. It adds space so that when the rim sits on the hub it gives you the extra space you need to clear the rim from the caliper.
I got it from this place www.visionautosports.com. Its like a 2 or 3 bucks for two I think. All you need is two for the front. The rear has no problems with clearance but i'm sure you know that.
good luck!
good luck!
MetalGearTypeS
08-29-2016 08:28 PM
adreano17
09-29-2015 08:48 AM
