My Turn to Reminisce....
Old 10-08-2012, 02:04 PM
  #81
@Mikeshlong On IG
mikebikelife's Avatar
I didnt write a DIY for it, rockstar143 did though. Its pretty much the same thing. What info did you want?
His DIY is at the top of my browser still I don't wanna loose the thread
But its for the 3g tl .
Basically :, take off wheel , unbolt caliper and hang it , Unscrew screws and take off rotor, cut slice in dust cover , knock out old, insert new and tighten them all the way in , reassemble ? And which studs should I buy ? My lugs are already open ended so any extra length won't hurt .
Someone in BM was selling some ichiba 10mm spacers and I was debating picking them up .
Thanks Morgan
Old 10-08-2012, 03:00 PM
  #82
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,140 Likes on 4,807 Posts
Originally Posted by JCharged
I've been back.
Thanks Morgan
Depends on what length your looking for. I went with the ARP 100-7712K. Theyre about an inch longer then stock IIRC (25mm). The lug studs are the same from 1980-on, just remember that you need 20 of them, not 16.
The front was easy to install. Due to the length of the studs I used, I had to remove the rear hubs from the spindles. Not a big deal, but just make sure you have the tools to do it. A shop manual helps just in case anything goes wrong.
I dont know what wheels your running or what offset, but if they arent reall aggressive and you want to run 15mm or larger spacers, just get the spacers that have the studs pressed in them. Theyre so much easier to deal with.
mikebikelife (10-10-2012)
Old 10-08-2012, 06:32 PM
  #83
StreetKA's Avatar
well if you dont go to the track this time i swear i will go all the way to VA just to key your shit !
The following 2 users liked this post by StreetKA:
97BlackAckCL (10-19-2012), JCharged (10-09-2012)
Old 10-08-2012, 06:39 PM
  #84
civicdrivr's Avatar
That might improve the way it looks at the moment
Old 10-09-2012, 02:55 AM
  #85
@Mikeshlong On IG
Shop manual ?
I'm running 42/45 offset (I always forget, smh ) on 8" wide, 225/40/18 . No camber kits . What I was gonna but was 10mm to start off , I need to flush the rear some more I feel hellasunk .
Next tires on these wheels are gonna be 215 more than likely .
Oh , and did you custom make your sub box ?
EDIT: I just don't understand the differences there's so many different arp studs, I just want strong and long ( ) I don't really care if they stick out the end of the lug a bit . I've also heard if you use the kind that bolt to the hub you have to cut your stock ones .
Old 10-09-2012, 04:01 PM
  #86
civicdrivr's Avatar
Shop Manual. If you dont have one you need it.
You dont have much extra space to go up front. Id think probably 5mm at most. The rear can go at minimum another 10mm. I ran 19x8.5 +40 with 235/40s and didnt rub, but I did have the fenders rolled and the bumper tabs trimmed. My wheel sat an additional 8.35mm outboard if +42, or 11.35mm is +45. How much of a stretch do your tires have?
Old 10-10-2012, 02:29 AM
  #87
@Mikeshlong On IG
Not much , its a 8" rim and 225. Could run a 205 and call it a serious stretch , or run a 235 and call it normal , imo .
But as for the front, i pulled the wheels off today and im showing threads and cords on the inside , so I'm gonna throw on some 215's or 205's and run a 10mm spacer .I have faith in it ! I'm driving on oems for the meantime. (should have got an allignment after my drop )
So I should buy a 15mm hub spacer that bolts on the hub and I won't have to cut my stock studs ? As well as these are safe and arent gonna make me have a missing wheel in a corner ? And for the front I should replace the lugs with arp studs # ...... ?
Where do I get a shop manual ? Give me yours, it doesnt have instructions on the frs :P
Old 10-10-2012, 11:51 AM
  #88
civicdrivr's Avatar
For as long as I have the CL, I will keep the manual. Its Helms pn 61S3M02.
Tons of people run the spacers with the studs built in without an issue. Just make sure you install them correctly.
Old 10-10-2012, 02:59 PM
  #89
@Mikeshlong On IG
Would you know what the best brand of spacers are ?
Old 10-10-2012, 03:52 PM
  #90
civicdrivr's Avatar
People are running the Ichibas. I had mine custom made by a company out in Nevada since I wanted them hubcentric to the wheel and car.
http://www.motorsport-tech.com/
Old 10-10-2012, 04:24 PM
  #91
@Mikeshlong On IG
They seem like a good company . Reasonably priced products too . Might have to pick a set of those up for my not so tl . lol .
Old 10-11-2012, 01:23 PM
  #92
Membistered Regember
jaeravenal's Avatar
I forgot to mention that it was in the 50s today. I was freezing. And I realized Im going to really miss heated seats if I ditch the CL
YOU KNOW YOU WILL DON'T DO IT, YOU CAN ROLL THE WINDOWS DOWN AND HAVE THE HEAT ON YOUR ASS AND YOU WONT EVEN FEEL THE FREEZEEEE BREEEEZEE!!
Old 10-11-2012, 01:40 PM
  #93
jaeravenal's Avatar
Yea, awesome videos Dreem1er!
holy sh*t my bad i meant you drivr this whole time,
was late that night to reply
civicdrivr (10-11-2012)
Old 10-11-2012, 05:13 PM
  #94
civicdrivr's Avatar
Suuuuuuure.
Old 10-16-2012, 02:44 AM
  #95
@Mikeshlong On IG
Did you build your sub box morgan ?
Old 10-16-2012, 02:06 PM
  #96
civicdrivr's Avatar
No, a vendor did. Hes no longer a vendor here though.
Old 10-16-2012, 02:07 PM
  #97
CLtotheTL32's Avatar
Received 9,493 Likes on 6,165 Posts
uncald4?
Old 10-16-2012, 02:43 PM
  #98
civicdrivr's Avatar
Yep. Last I checked he was no longer a vendor.
Old 10-16-2012, 02:45 PM
  #99
Yeah he left two years ago or so.
Old 10-16-2012, 08:26 PM
  #100
MD03CL-S's Avatar
Damn, I go MIA for a little and here you are getting ready to part her out
ok, I'm going back to hibernation
Old 10-17-2012, 11:02 AM
  #101
civicdrivr's Avatar
Stay for a while!
Old 10-17-2012, 11:07 AM
  #102
We miss you Quaye!
Old 10-17-2012, 06:43 PM
  #103
MD03CL-S's Avatar
meh...
Old 10-17-2012, 07:34 PM
  #104
civicdrivr's Avatar
Old 10-18-2012, 11:57 AM
  #105
Learning New Ways!
Xcivicb's Avatar
Love the car man, what kind of shift knob is that??
civicdrivr (10-18-2012)
Old 10-18-2012, 12:07 PM
  #106
@Mikeshlong On IG
"My very first mod was the 8G Accord shift knob."
Old 10-18-2012, 12:16 PM
  #107
Learning New Ways!
Xcivicb's Avatar
Thanks on the info, this will be my 3rd mod actually....
Old 10-18-2012, 03:28 PM
  #108
civicdrivr's Avatar
Yea, the one pictured is from an 8G Accord. I still have it if you want it. Im not using a S2000 knob.
Old 10-18-2012, 04:08 PM
  #109
Learning New Ways!
Xcivicb's Avatar
You in NOVA right?
Old 10-18-2012, 04:49 PM
  #110
civicdrivr's Avatar
No, SoVa.
Old 10-18-2012, 10:23 PM
  #111
Chapter Leader (Southeast Region)
Stephen00TL's Avatar
Are you doing the dual throttle body set up made by paul before you get rid of it? if that's what your doing?
Old 10-19-2012, 08:26 AM
  #112
civicdrivr's Avatar
Old 10-19-2012, 08:29 AM
  #113
JCharged's Avatar
Old 10-19-2012, 09:30 AM
  #114
I thought you said you were finishing up a few mods on the cl?
Old 10-19-2012, 09:31 AM
  #115
civicdrivr's Avatar
Yea, the retrofit that Ive been working on for a long time.
Old 10-19-2012, 09:41 AM
  #116
Oh I wasn't even close lol never mind
civicdrivr (10-19-2012)
Old 10-19-2012, 12:00 PM
  #117
Lone Wolf
brian6speed's Avatar
What is the point? Did you change your mind on selling the car?
mikebikelife (10-19-2012)
Old 10-19-2012, 12:02 PM
  #118
Yumcha's Avatar
Received 22,648 Likes on 13,889 Posts
Wait...M, you still own your CL? Could've sworn you got rid of it.
Old 10-19-2012, 12:09 PM
  #119
@Mikeshlong On IG
Not quite . I want that sub enclosure when the car goes bye bye .
Old 10-19-2012, 12:28 PM
  #120
civicdrivr's Avatar
I have them apart, the buckets are cut up, so might as well finish it then sell them when I part out.
Nope, still got it.
Quick Reply: My Turn to Reminisce....
