Honda Accord fogs
Old 05-04-2011, 09:55 AM
99 TLS6 08 TL
timberland73's Avatar
Honda Accord fogs
Got the Accord fogs in my 03 CLS6, thought I'd take a few pics. Not the cleanest job, but I'm happy with the outcome.
Old 05-04-2011, 12:30 PM
Former Sponsor
rondog's Avatar
Actually works pretty well.
Old 05-04-2011, 12:46 PM
p.diddy's Avatar
Originally Posted by rondog
actually works pretty well.
+1
Old 05-04-2011, 03:10 PM
Sleuy1's Avatar
was it a direct fit or did u have to modify it a little? i was planning to do the exact samething bt didnt know if i had to modify it or not.
Old 05-04-2011, 05:30 PM
99 TLS6 08 TL
Had to do a lot of cutting on the housings (which is why they aren't completely even) but not that big of a deal.
Old 05-24-2011, 02:47 AM
willdollas's Avatar
I've been looking into putting foglights on my 01 cls myself was it hard to do?
Old 05-24-2011, 09:58 AM
RideCL's Avatar
solid!
Old 05-27-2011, 06:01 PM
cu0ngsayz's Avatar
i was thinking about doing this... looks good man... minus the unflush fog hahah
Old 05-29-2011, 11:39 PM
Finally Registered
o0o0o0's Avatar
can these handle HID heat?
Old 05-30-2011, 03:41 AM
cu0ngsayz's Avatar
yes these can handle HID...
Old 06-07-2011, 11:19 AM
99 TLS6 08 TL
Not too bad.
Originally Posted by RideCL
solid!
Thanks!
Thanks! The fogs aren't supposed to be flush. I actually prefer them unflush, less chance of rock chips.
Old 06-08-2011, 04:50 PM
CLkid187's Avatar
that came out sweet! i wanted to do tha xact same thing to. did you have to do any wiring cuz i see you can have the fogs on w/o the headlights? hid's would really have them rite!!
Old 06-08-2011, 07:25 PM
99 TLS6 08 TL
Just the wiring that came with the kit. It was all basic wiring though. Nothing too confusing/fancy.
Old 06-13-2011, 10:11 AM
Juice
CL Juice's Avatar
They look good. I was planning to put those on my cl. From the looks of it, seems pretty simple to do.
Old 06-13-2011, 01:25 PM
Unregistered Member
Karanx7's Avatar
Looks good. The one on the right is great, but the left one is a little off.
Old 06-14-2011, 04:16 PM
99 TLS6 08 TL
Thanks! Yeah, I got a little trim happy when I was cutting that side.
Old 06-16-2011, 07:40 PM
Chamorro
dave586270's Avatar
Good stuff! Just looking around for a set of these myself! Did you use the button it came with to turn 'em off and on? What did you tap into?
Old 06-17-2011, 10:15 AM
99 TLS6 08 TL
I used the button that came with the kit but I'm not happy with it. It's not quite the right size for the hole and it always stays on or off. I can't actually push the button. I have a switch that fits properly but the wire connector is different. I don't know exactly what I'm gonna do with it yet. Sooner or later I'll splice the wires to make it work or buy the wiring pigtail for a four door Accord. I have it set to stay on so when I turn on my driving light they automatically turn on. I might even leave it the way it is because I never really need to turn them off.
Old 06-17-2011, 01:33 PM
Chamorro
dave586270's Avatar
Yeah id probably just get the oe button from honda so that it will fit in there and work right. What did you tap into for power though? The '01's have power cause there are the lame parking lamps. But those must have needed a little more juice?
Old 06-20-2011, 08:26 AM
99 TLS6 08 TL
They're wired to the parking lamps. I have the OEM Honda switch but it's for a four door. It fits perfectly fine but the wiring is different for that switch. The switch I'm using is for a 2 door but it doesn't fit right, the wiring is correct though. It sucks. I used Accord fogs for my 99 TL as well but didn't have the switch issue because both cars are 4 door.
Old 06-20-2011, 08:42 AM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,408 Likes on 3,020 Posts
clean
Old 06-21-2011, 10:27 AM
99 TLS6 08 TL
clean
Thanks!
Old 10-09-2011, 01:15 AM
RSpyder's Avatar
What year was the accord with those fogs???
Old 10-09-2011, 08:21 AM
p.diddy's Avatar
03-05 2dr accord.
Old 10-14-2011, 12:34 AM
AM To WDP In My Garage
acura_dipset_tl's Avatar
do you guy's think the 4dr 05 accord fogs will fit too? its seems that the bezels are the only difference between the 2dr and 4dr accords.
Old 10-27-2011, 10:31 PM
Rollin the SRT8 or my CLS
Mr3.2S's Avatar
What types of housing are these?
Old 10-27-2011, 11:48 PM
cu0ngsayz's Avatar
i think you would have to make a bezel if youre gonna use the sedan. why dont use just the coupe its already made kinda the same as the CL.. well shape wise.
Old 10-28-2011, 11:55 PM
so the coupe bezel won't fit the seda fogs? They only reason i wanted to use the sedan fogs is because i can get them for dirt cheap and they are oem.
Old 10-29-2011, 03:02 AM
m733l's Avatar
^ you'll need to modify fitment either way. the coupe fitment is close but still needs to be modified to fit. you also need to get creative to get them to mount.
snorf
11-04-2019 06:44 AM
csmeance
09-10-2018 09:15 AM
InFaMouSLink
10-27-2015 06:51 PM
Lucrativesoldier
09-28-2015 03:47 PM
cruisingnycfl
09-02-2015 12:11 PM
Quick Reply: Honda Accord fogs
