DLntheCL's lip kit build
Old 01-06-2013, 05:44 PM
DLntheCL's Avatar
been planning this for a little while but i never liked certain things about the TL lip kit a lot of guys have, but when i found the infamous ebay lip i had a plan....
most dont like this lip with the cut-outs because it "frowns" so i went to lowes/home depot and got a 1 1/8'' strip of vinyl moulding. i wanted something that could bend but also was sturdy, this fit the bill. i used this to fill the void of the "frown"
i still have plenty of body work and sanding still to do, this was just a weekends work. im going mold the kit on seamless. im going with wings west rear (i like it better than OEM) and sides are still TBA, im not a huge fan of TL sides, some look good, some dont, so not gonna use them
as far as the ebay lip, with a little dremeling it fits on really well. i noticed before i tweaked it, the fit was too tight and made the frown even worse cus it was bending itsself. after cutting and taking the pressure off the sides it relaxed and "flattened" out.
Attached Thumbnails DLntheCL's lip kit build-one.jpg   DLntheCL's lip kit build-two.jpg   DLntheCL's lip kit build-three.jpg   DLntheCL's lip kit build-four.jpg
mikebikelife (01-07-2013)
Old 01-06-2013, 05:54 PM
DLntheCL's Avatar
before i used glass filler this is what the vinyl strip (painted black) looked like. i used plenty of epoxy and 7 brackets so its not going anywhere.
Old 01-06-2013, 07:36 PM
3.7L Nitrous Breathing CL
richardparker's Avatar
Looks great.
flows really well with the front.
Old 01-07-2013, 02:12 AM
@Mikeshlong On IG
mikebikelife's Avatar
I like . How much was the front ebay lip ?
Old 01-07-2013, 09:15 AM
CLtotheTL32's Avatar
Received 9,493 Likes on 6,165 Posts
In for moar!
Old 01-07-2013, 03:47 PM
DLntheCL's Avatar
i think 160 including shipping from canada, which was extremely quick. opened the box and there was a small crack on the lip but it could have been worse considering it was simply placed in a cardboard box and nothing more
Old 01-07-2013, 10:51 PM
njlakeshoreg's Avatar
the modification to it loooks real tuff bro nice work!
Old 01-08-2013, 10:37 AM
Metal Swantoon
SwedishMickeyMouse's Avatar
Looks great, i've been wanting to buy that same lip kit so it's good to see how it actually looks
Old 01-08-2013, 10:48 AM
DLntheCL's Avatar
[QUOTE=SwedishMickeyMouse;14250106]Looks great, i've been wanting to buy that same lip kit so it's good to see how it actually looks[/QUOTE
thanks, yeah id jump on it...still figuring out what im going to do for side skirts
Old 01-08-2013, 10:51 AM
DLntheCL's Avatar
started moulding front lip, even with just fiberglass filler and 100 grit sandpaper its pretty damn smooth.
Attached Thumbnails DLntheCL's lip kit build-molded1.jpg   DLntheCL's lip kit build-molded2.jpg
Old 01-15-2013, 05:25 PM
DLntheCL's Avatar
wings west rear lip came in today. i know everyone has been cutting theirs into 3 pieces, i was set on doing so as well but when fitting the kit on i liked the idea of just chopping off the ends better, i will epoxy the "caps" back on to give it the finished look. side skirts i used strait bars of vinyl. i had to cut them at an angle to match the downward shape of stock skirts. these skirts are now strait down, dont point in or out and dont stick out past stock skirts. everything has been epoxied and screwed down (i find this to be just as good as clamping if not better.) ill fill in holes with filler when i mold these in. i plan on smoothing out the hard edges of the side skirts as well.
still cant make up my mind on paint
Attached Thumbnails DLntheCL's lip kit build-kit2.jpg   DLntheCL's lip kit build-kit3.jpg   DLntheCL's lip kit build-kit4.jpg   DLntheCL's lip kit build-kit5.jpg   DLntheCL's lip kit build-kit6.jpg
Old 01-15-2013, 07:15 PM
Metal Swantoon
That will look so sweet, nice man and i took your advice and ordered the full kit from that dealer in canada
Old 01-15-2013, 07:19 PM
ArthurL's Avatar
The car looks great man. Can't wait to see it finished. And btw is that a stock color for the CL?
Old 01-15-2013, 08:28 PM
In search of excitement
kingofdust's Avatar
Arthur yeah it is!
DL unreal man, looks amazing, what are you dropped on btw (cant remember)?
Old 01-16-2013, 04:28 AM
97CL_NC1102's Avatar
im surprised i havent seen this thing around...looks good
Old 01-16-2013, 06:00 AM
DLntheCL's Avatar
Yes oem color- sundance gold, only available in 2001.
I'm lowered on k sport coilovers
Thanks for the props guys
Old 01-16-2013, 11:47 AM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,408 Likes on 3,020 Posts
can't wait to see the finished product
Old 01-16-2013, 11:49 AM
Damn, awesome progress. I love the lip kit for the 2G CL/TL
Old 01-16-2013, 12:24 PM
@Mikeshlong On IG
Where's the vinyl from ? Give us a little moar info so we can get moar ideas
Old 01-16-2013, 03:00 PM
DLntheCL's Avatar
Lowes, comes in 8ft lengths and no they will not cut it down but yes it will fit thru the ski pass. It's 3.5 inches in height (iirc) and was what I needed exactly for the side skirts, anything taller and the ground clearance would be less than the front lip.
On the backside you must cut it at an angle fit it to sit flush against oem sides but be perpendicular to the ground.....I'll take a pic
mikebikelife (01-16-2013)
Old 01-16-2013, 06:02 PM
DLntheCL's Avatar
side skirts. i will cap off ends to give it a finished look. still have sanding and body filler work to do
mikebikelife (01-17-2013)
Old 01-16-2013, 06:14 PM
DLntheCL's Avatar
heres a pic to compare OEM rear vs wings west rear.
Attached Thumbnails DLntheCL's lip kit build-tlrear.jpg   DLntheCL's lip kit build-wwrear2.jpg
Old 01-20-2013, 06:45 PM
DLntheCL's Avatar
rear lip molding in progress
Attached Thumbnails DLntheCL's lip kit build-photo-1.jpg   DLntheCL's lip kit build-photo-2.jpg   DLntheCL's lip kit build-photo-3.jpg
Old 01-21-2013, 12:50 PM
@Mikeshlong On IG
Looks good . The rear is a molded ww right ?
Old 01-21-2013, 01:42 PM
DLntheCL's Avatar
Yeah
Old 01-27-2013, 03:31 AM
@Mikeshlong On IG
Any update/ progress ? I love how this is going ...
Old 01-27-2013, 05:25 AM
03 acura cl type s
rush's Avatar
Nice! never seen one in this color great work
Old 01-27-2013, 09:28 AM
DLntheCL's Avatar
not a whole lot, its been raining/hailing/freezing temperatures last week so havent gotten to do much. today(if weather permits) i plan on finishing bumpers with the finishing filler (evercoat rage extreme). im still waiting on sandpaper/sander. i also ordered this a product called presta scuff stuff for bumpers and spoiler, supposed to work well as far as removing clear coat/paint on plastics.
i still have plenty of work to do but kinda at a stand still till everything else arrives. lll keep updating, as long as i have some good weather and warm days i want to be done with everything before march
mikebikelife (01-27-2013)
Old 01-30-2013, 06:13 PM
DLntheCL's Avatar
did some sanding today, still have drivers side to do. major bump for scuff stuff, shit works wonders. paint colors change every few days but i think im set on BMW Laguna Seca Blue, and going to paint the wheels white. i think it will look really nice with the light blue tint
i really like the car without the spoiler but since i permanently removed 3rd brake light i need a spoiler with brake light. chances are going to keep OEM but with clear brake light, and going with 03 tail lights. keeping 01 headlights and fogs (with no bulbs right now)
Attached Thumbnails DLntheCL's lip kit build-sanded1.jpg   DLntheCL's lip kit build-sanded2.jpg
Old 01-30-2013, 07:46 PM
Can't wait to see this with fresh paint.
Crown town, Is that Charlotte ?
Always wondered seeing your location.
Old 01-31-2013, 09:15 AM
DLntheCL's Avatar
Thanks man, yeah sometimes it's hard to believe im going to have a diff color car, but it needed work. I think i counted 21 dents/small repair areas including both doors, both fenders and both bumpers, none so big to create a huge eye sore but enough to want everything fixed and fresh paint on whole car. The only thing that sucks is my choice of season to do this. Depending on weather I hope to primer and final stages of paint prep next week.
Yes queen city/ Charlotte
Should have car painted by end of feb
Old 01-31-2013, 09:56 AM
(Mid-Atlantic)
Old 02-01-2013, 02:55 AM
bluedc2's Avatar
Small world...I'm located in Charlotte to, near northlake mall. I wrecked my CL but I got another one. Lip kit is looking good!
Old 02-16-2013, 05:58 PM
DLntheCL's Avatar
things are coming together. side skirts are finished, front lip is finished, still have some shaping and sanding to do on the rear. ive been toying with the idea of a front chin spoiler, mainly to protect the lip. i dont want that cheap adhesive rubber strip and since no one makes one for our car i did a little research and found that many people have been making them out of alumalite, same material that highway signs are made out of. i can get a 1/4" 4'x8' sheet local for 150 bucks. before taking the plunge i went to lowes and got 1/4" sheet of plywood and made a mock-up to see how i like it, how it looks and to have a template for all of my mounting holes. i couldnt mount it on my car cus its snowing outside but ill snap some pics with it on asap. the subaru is just an example of the look im going after. i was going to extend the chin past the lip but it just hangs slightly outward, i may bring it out an inch or so in the front. not sure yet
Attached Thumbnails DLntheCL's lip kit build-subchin.jpg   DLntheCL's lip kit build-chin2.jpg   DLntheCL's lip kit build-chin.jpg
Old 02-16-2013, 10:55 PM
SICK!
Old 02-17-2013, 12:16 AM
AM To WDP In My Garage
acura_dipset_tl's Avatar
It's looking great, I can't wait for the finish product.
Old 02-17-2013, 09:15 AM
Metal Swantoon
I love the underlip idea, i think do it.
Old 02-17-2013, 11:58 AM
@Mikeshlong On IG
You could sell this kit for 1k after you're done , its so damn sick .
Old 02-17-2013, 12:56 PM
Metal Swantoon
I have an oem spoiler if you need one
Old 03-03-2013, 11:01 PM
Wilfred_PR's Avatar
Awesome job my man! now I'm between a CL and a tsx!!!
Quick Reply: DLntheCL's lip kit build
