Camber Kit for 2003 3.2CLS
Do you need to put a camber kit in if you install the Eibach Pro kit springs? I know it says 2 and 1.6 but i am afraid it might sit even lower after settling? Anyone know?
Thanks,
Thanks,
Enjoy the Ride
hobes,
i have that setup and you definitely need at least the rear camber kit. i had upgraded to a larger rim size and had to get everything checked and the camber was off by quite a bit. i don't know how it was with the stock rims size but i'm pretty sure you will need the rear. go to groupbuycenter.com to look for a camber kit, thats where i got mine. hope this helps
Do you think i will need a camber kit if i put in the comptech springs instead? The drop is only 1.5 and 1 F/R respectively. I am also putting in 18"...what kind of rims did you put in? Do you have pictures? Thanks,
Enjoy the Ride
hobes i don't know if you are going to need a camber kit for the comptech springs. my guess is you won't because the front on the eibachs are 2.0 and i didn't need the front camber kit. i actually just installed the rear one today. going to get the alignment and camber adjusted this weekend.
i don't have pics yet because i'm waiting on my friend to send me the link where he has the pics. but i'm running on 18 inch racing hart c2 evos.
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-28-2015 05:43 PM
