Tensioner update affected VINS
#41
I got mine tensioner serviced on Monday when I went into John Eagle Acura for an unrelated problem. Man what a difference! My car feels more powerful now and the revs are louder. The timing belt must have been real loose before I went in at 27k.
#45
just register the car with owner's link and it will tell you if the car is affected. thankfully my car is NOT affected and purrs like a kitten on steroids :P
#46
did register, got two recall options,
02-03 V6 ENGINE WATER PUMP
00-04 CL & TL A/T RECALL
But it looks like these parts been serviced before by previous owner, Is the second one for the Tensioner?
#47
A/T recall is for the oil jet kit on the transmission for the 2nd gear shaft if it says fixed, you are good
#49
2003 Acura CL-S6
Perhaps the moderators could make this a sticky for a bit 'till Acura can notify the affected vehicle owners?
2002 CL VIN no's 19UYA4...2A004260 thru 19UYA4...2A005879
2003 CL VIN no's 19UYA4...3A000001 thru 19UYA4...3A009883
If you have a CL or CL/S with a vehicle identification number that falls into the ranges above you should be recieving notification for t-belt tensioner update .
2002 TL VIN no's 19UUA5...2A052043 thru 19UUA5...2A061706
2003 TL VIN no's 19UUA5...3A000001 thru 19UAA5...3A043888
If you have a TL or TL/S with a vehicle identification number that falls into the ranges above you should be recieving notification for t-belt tensioner update .
Upon receipt of this notice from Acura you should contact your dealer and make arrangements to have the car brought up to spec .Or let them know at your next service visit that you think your car may fall under this update and have them bring the car up to spec as needed .
Jens
Jens
I have a 03 CL-s
VIN:3a00290
joflewbyu2
10-08-2015 11:16 AM
