2G CL Frequently Asked Questions No New Threads Please.
DIY Ballast replacement
Old 02-02-2008, 08:41 PM
9th Gear
MrMT's Avatar
Hello,
Has anyone here replaced the ballast on the right side? Can you tell me how to do it? 2003 CL
Old 02-07-2008, 09:55 PM
Go Gators
OscarCL3.2's Avatar
It's actually quite simple.
You need a slotted screw driver, phillips screw driver, 10mm socket, another socket slightly smaller than that (not sure of size...test for fit), and a tamper proof bit set
Removing Bumper (Tools = Solotted Screw Driver; Phillips Screw Driver; 10MM Socket)
1. Remove screw in front of each front tire (where bumper meets front quarter panel on each side). (Should be Phillips SD)
2. Remove plastic pins from the underside of bumper (4 of them). (Using Slotted SD)
3. Remove 10MM Bolts from underside of bumper. (2, one on each side)
4. Remove plastic clips on top of bumper. (8 or so)
5. Remove screws on top of bumper. (3 screws, using Phillips SD)
6. Unplug foglights. (for 01-02 models)
7. Remove bumper.
Removing Headlights
1. Remove Bumper
2. Remove bolts from the side of the headlight housing.
3. Remove two bolts under the headlight housings.
4. Unplug connections.
5. Remove two bolts from the top of the headlight housing.
5. Remove headlights.
Removal of Ballast
1. You have to use the tamper proof bit to open the housing to get to the xenon bulb. The screw is near the plug for the bulb's power.
2. Remove power connector from the bulb.
3. Remove the ballast from the lens/housing with a phillips screw driver.
To replace...just follow the steps in reverse order.
Old 02-08-2008, 11:08 PM
9th Gear
MrMT's Avatar
Hey OscarCL3.2,
Thank you for all the info. I'm going to try and replace it this weekend. Thank you for all your help.
MrMT
Old 03-20-2011, 01:04 PM
AARONSredTYPE-S's Avatar
i will doing this soon
Old 08-21-2011, 09:17 PM
6th Gear
BlackClNova's Avatar
I had one ballast out so I but a d2r kit online and switched out both ballast and a relay harness to gain power directly from the battery. Will post posts asap.
Old 04-02-2012, 06:29 PM
5th Gear
kux03's Avatar
I had one ballast out and decided to do a complete conversion. Check out this thread ---https://acurazine.com/forums/showthread.php?t=716617--- it was a lot of help when getting acquainted with everything.
The conversion kit I used was the one mentioned here- https://acurazine.com/forums/showthr...=788745&page=1
couldn't be happier, especially with the amount of money I saved.
Old 05-10-2017, 11:59 AM
IHaveNoIdea2012's Avatar
Stay away from HIDExtra - there terrible.
Old 03-19-2020, 03:10 PM
Robert Legette's Avatar
Are y'all talking about the headlights
forcemac101
07-03-2012 11:56 PM
simran4h
04-03-2011 10:34 AM
erick3
02-16-2010 04:43 PM
rob-2
03-22-2008 02:30 PM
Royal_Dragoon
06-28-2006 04:48 PM
Quick Reply: DIY Ballast replacement
