2G CL Frequently Asked Questions No New Threads Please.
2001 CL-S Exhaust size
Old 01-12-2005, 12:58 PM
Sims's Avatar
I did search but came up dry.
What size pipes come stock on the CL-S exhaust?
TIA
~Mike
Old 01-13-2005, 06:43 AM
Sims's Avatar
c'mon. Somone must know the size of the stock exhaust pipes??
Old 01-13-2005, 06:49 AM
JnC
Former Sponsor
JnC's Avatar
I am not sure but from the looks of it it seems to be 2.25 inch, just make sure though.
Old 01-17-2005, 10:24 PM
Adventurist.
NiteQwill's Avatar
The piping varies from cat to muffler
Old 01-17-2005, 10:28 PM
Adventurist.
NiteQwill's Avatar
Here is the piping size:
Old 11-19-2015, 01:33 PM
mike88se's Avatar
There doesn't seem to be a definitive answer here unless it was in the links that no longer work. The piping from the cat to the y for the mufflers is 2 1/8" OD so the ID would be 2" or a little less. The piping from the Y is... very small. I didn't measure that but I'd estimate 1.5" OD.
Old 11-19-2015, 01:36 PM
Be a better driver
RedRyder's Avatar
It was 2" on my car (CL's sister car), so I'd venture to say the CL is 2" as well.
mike88se (11-19-2015)
Old 11-19-2015, 01:42 PM
mike88se's Avatar
ID of the cat to Y pipe right?
Old 03-05-2017, 11:00 AM
Transmission Pro
Bense's Avatar
If you look at the parts catalog for the CL, and find the gasket that goes between the exhaust header and the exhaust, the part description will tell you the size in mm.
Old 03-05-2017, 11:02 AM
Transmission Pro
Bense's Avatar
18393-SS0-J30 Gasket, Pre Chamber (57.5MM-58.5MM)
So, 2.25" for the type S.
Old 01-04-2018, 01:54 AM
cls6life's Avatar
Good to know, thank you:gheywave:
Pham Alvan
05-18-2021 06:48 AM
Pham Alvan
03-16-2016 09:17 AM
ExcelerateRep
10-14-2015 08:20 AM
swany0095
2G TSX Performance Parts & Modifications
10-07-2015 02:18 PM
dirleton
09-25-2015 12:25 AM
Quick Reply: 2001 CL-S Exhaust size
