cl 03 255hp/224tq 116k
http://i4.photobucket.com/albums/y15...g?t=1238626700
aem cai xs power headers greddy mx aasco flywheel runs were ran back to back. disabled/opened imrc. dynojet at dynomite tuning. videos will be up |
your torque is really low. whats with that?
is this a 6 speed?
good #s, they are on par. I believe it is a 6spd
did the flywheel give you good gains?
Originally Posted by phee
(Post 10723919)
low?? dont cls put down around 215? 225lbs tq doesnt feel low. flywheel just gave it faster revs. gains probably similar to pulleys. but the shift engagement is what i like. |
where did u get the flywheel and how much did it run u?
That's about right. Mine dyno's just about the same.
Originally Posted by L's TL
(Post 10725214)
google aasco cl flywheel. ran about 1k i think. as for the really low torque? dude i dont know what your looking at. my torque line is solid. almost 220lbs @ 2.5k rpm |
^^^ ur TQ is where its supposed to be. Thanks for the info on the flywheel. I think ima go clutchmasters
Aaah so this is what you were talking about Evan, hey hit me up if you find pics of my Accord on the TSX forums. I know when I did mine and got 252 on a dynojet the guy leaned it out a bit much and as a result the ECU was retarding timing a little. Ill get another dyno one of these days, this time with bigger brakes.
So far I got: UR crank pulley AEM CAI Comptech headers straight pipe>2.5" piping>(2) Cherry Bomb glass packs> HKS Superdragger axleback. ported/poished IM top and bottom Id say your A/F is a little low, I think 13.0-13.5 is best for NA. |
nice #'s i finaly ordered my AASCO flywheel 2 weeks ago....im sure u would make a lil more power if u were to lean it out a bit more....i know my motor doesent like alot of fuel i likes high 13's Air Fuel
Originally Posted by Pinho
(Post 10743554)
My car starts to ping a bit at high 13's especially in VTEC. |
Originally Posted by Accord_V6_400m
(Post 10744224)
So why Aasco and not Comptech or better yet Clutchmasters or Unorthodox Racing flywheel?
i really like my aasco, but i wish i would have researched the ur flywheel before purchasing...you can get them for $619.00 on www.dikperformance.com
i do want a tune my a/f in the future but after couple more mods...and i still havent figured what i want to tune with yet either. |
Originally Posted by sinfulj32
(Post 10748972)
(Post 10748972)
yah i think i got mine for around 650 new but the install was another 400...hmm i dont think i'll be in la area this week, but i'd be down to meet up sometime..
looks like a failed imrc to me
Originally Posted by typeR
(Post 10758011)
I actually did drop by Aasco, and im quite impressed. Got pics that i'll post up later, they actually had one of our flywheels right there on the table and more being built. Talked with Vincent I believe was his name for almost an hour or should I say listened. I found out that Aasco makes pretty much every other companies flywheel for them including clutchmasters however not Fidanzas and no longer for UR but due to private labeling laws they will naturally deny this. Their Porsches will be racing at the Long Beach Toyota Grand Prix preview is today too if I remember correctly. Flywheel specs: 13.0lbs (weighed it right there) stock: 33-34lbs (good estimate from Vincent's memory) (almost a third of the weight) Specs: 425hp 3.8 NA motor 9000rpm redline Powerband 6K-8200rpm Engine: $45000 engine service life: 40hrs Operation costs: $5000 a day |
^nice info.
yea one of the main reasons why i went aasco is because i knew they made awesome porsche flywheels |
Sounds nice.
Greddy MX is a single unit axle back? Or is that custom?
i bought the dual mx but came with an extra elbow for single exit option for 4cyl accords
i have injen intake comptech axleback how much whp would that be ? does UR pulley worth that price any hp gain ? on stock i ran 14.341/ 97.4 (6spd)
Originally Posted by StreetKA
(Post 10774650)
Finally modded my Comptech j-pipe to have a 2.5" collector! Think it got faster ;)
And I threw on a CLS cat so I can pass smog :D |
did you have a shop mod it? do you mind if i see how you did it? you'll probably feel the gains when you put your straight pipe on again
(Post 10788282)
I'll get some pics up later the shop said they would do the work for $200 actually took a couple of hours to do, so it makes sense, parts and labor combined (piping and new flex pipe). Right now the cat has one flange on it to allow for the removal of the j-pipe, and welded on the otherside, i'll add another flange to it to put in a test pipe after my smog check if anything just to try it out and see if Evan is right about the cat. Now I can confidently say the cat is probably the most restrictive part of the exhaust since everything else is 2.5" or splits into 2.25" at the axleback. |
nice. did that shop mod your stock cat to 2.5 to?
(Post 10794313)
(Post 10790742)
I felt the gains regardless, the cat doesnt hurt it much at all, especially since I modded the cats inlet/outlet sizes to match that of the 2.5" piping, so it doesnt restrict back to 2.0"
How the hell did they mod the cat into a 2.5 I don't get it?
Originally Posted by CG2PROJECT
(Post 10796160)
Ill try it straight piped after smog and see if it changes performance. |
damn, nice numbers on this, especially with the mileage.
hope when i get my dyno soon, that i have as good or better...lol |
single Greddy exhaust and it sounds just like mine.
