wow! is a neuspeed front strut bar for CL's extinct?
I Wanna Beer
May or may not actually be available here:
Down South Customz - Online Performance Shop
The Cusco brace is readily available.
https://www.heeltoeauto.com/cusco-fr...roductid=53092
hue_hustler (10-19-2014)
hue_hustler (10-20-2014)
hue_hustler (10-21-2014)
I Wanna Beer
3.5 psi
the strut bar in the engine bay won't have much noticeable difference. Just get a rear sway bar. I'm going off memory, but i think the comptech rear bar is 22mm, eibach is 23mm and progress is 24mm. You'll want new oem or moog endlinks with it.
I Wanna Beer
This is true. The strut tower brace is pretty much for looks with a very small effect on handling. If you want the best bang for your buck, rear swaybar is going to be the way to go.
The Progress bar that is designed for our cars is 22mm. To get the 24mm bar you have to select the Progress 3G TL rear sway bar. Fits perfectly, and it's the one anyone with a 2G CL/TL has if they have a 24mm bar.
I finally got a Neuspeed Front Strut Bar
I finally got a Neuspeed Front Strut Bar for my 2003 Acura CL-S!!!.... Thanks for everyone's help... U guys are great... !!!
If you want handling, you want BOTH sways. Replacing the front will do far more for handling than just the rear alone. Having a quality upgraded pair will help drastically. I can dial in or out oversteer or understeer simply by adjusting air pressure now.
Good to hear. Just remember, KEEP your factory one on with it. The OEM bar is a multi point (meaning it attaches near the firewall as well as the strut towers and offers more strength than just going across the towers
thanks alot. Both will be on... All advice is appreciated. im new to this acura world....
marcelft
07-10-2018 06:17 PM
acurajj
02-14-2016 02:28 PM
