Worth Getting Front Sway Bar?
Old 09-12-2007, 10:20 PM
Lives On BOOST
krisdlm's Avatar
Is it worth getting a front sway bar replacement? I been reading that only the rear makes a difference. For ppl trying to get the rear only, I found this site:
http://www.j2performance.com/store/a...-pid-5735.html
So, either the rear or set?
Old 09-13-2007, 12:03 AM
Dan
Dan's Avatar
I had the front & rear bars on for about (3) weeks. Made the car handle like it was 500+ lbs lighter, but I did not like what it did to the ride quality. The car is a big, heavy FWD barge. Enjoy it for what it is, a great long distance road car. RWD is for fun!
Old 09-13-2007, 01:23 AM
dhorman's Avatar
Check http://store.summitracing.com/egnsea...115+4294924653 for the same part at a little better price. You can also get the mounting hardware (real high quality urethane bushings, bushing lube, and brackets) for about 30 bucks.
Old 09-13-2007, 01:48 AM
Lives On BOOST
krisdlm's Avatar
is this all i need?
http://store.summitracing.com/egnsea...=KeywordSearch
Old 09-13-2007, 01:57 AM
Lives On BOOST
krisdlm's Avatar
does the front sway bar make a difference?
Old 09-13-2007, 05:20 AM
srehmat02's Avatar
Originally Posted by krisdlm
I would also like to know what else should be upgraded when putting on a new rear sway bar. What about better endlinks, would that make a difference?
Old 09-13-2007, 05:41 AM
Well...it's kinda fast...
2CLean's Avatar
^Definitely upgrade the crappy OEM endlinks. They look like they'll snap like a twig with the stiffer RSB. When I upgraded to the 24mm Progress RSB, I upgraded to Moog endlinks (p/n K90342 and K90343) which were a lot thicker and included grease fittings, plus they're only $18/ea as opposed to $120/set for the upgraded OEM endlinks.
Old 09-13-2007, 08:22 AM
Zippee's Avatar
Put bars on both ends of the car. Putting on just the front will increase understeer.
Old 09-13-2007, 09:35 AM
SOLD: 03 SSM CLS Auto
gaping46and2's Avatar
I felt more of a difference after replacing the fsb than rsb. I ran with the rsb for about two weeks, then installed the fsb.
Old 09-13-2007, 10:00 AM
horsepowercrzy18's Avatar
hey
both make a big difference
Old 09-13-2007, 10:40 AM
ASM I.S. Design FTW.
brianlin87's Avatar
upgrading the front sway is pretty worthless... aftermarket front sways have the same diameter as the oem ones.
Old 09-13-2007, 11:06 AM
CleanCL's Avatar
just replace the rear one and upgrade the bushings on the front.
Old 09-13-2007, 11:25 AM
hey
the aftermarket eibach front sway is bigger than oem
Old 09-13-2007, 02:27 PM
And it weighs more.
Old 09-13-2007, 03:53 PM
jlspeed29's Avatar
get the rear sway..i just did cant wait till i install it!
Dan
Dan's Avatar
But they are SOLID and NOT hollow.
Old 09-13-2007, 05:34 PM
2CLean's Avatar
^Actually, they're both 27mm hollow steel, the difference is in the wall thickness. Only the RSB is solid.
Old 09-13-2007, 06:40 PM
Lives On BOOST
krisdlm's Avatar
where can i get all the bushings n shit to install for a good price?
Old 09-13-2007, 06:41 PM
Lives On BOOST
krisdlm's Avatar
where can i get all the bushings, endlinks, etc. for a good price?
Old 09-13-2007, 07:27 PM
brianlin87's Avatar
excelerate
marcelft
07-10-2018 06:17 PM
Onyxthecat
10-18-2016 02:05 PM
drone619
01-26-2016 07:09 PM
k6biv
09-10-2015 06:37 PM
Quick Reply: Worth Getting Front Sway Bar?
