window regulator!
Socal
1 Post
window regulator!
i cant really find what im lookin for in the search. i knew there was a discount for azine on acuraoemparts or delray. i need to find a driver side window regulator for 03 cl-p. my shop wants to charge 250 for everything. is it an easy install? are the pulleys and everything already attached? i can find the part for 80 + shipping. just spent about 3k on a tranny/engine mount job and need to be budget minded
B A N N E D
yes everything comes as one, minus the motor itself, that has to be transferred over to the new regulator
and i am assuming the cable broke on yours also (actually the end of it held on by some plastic probably broke)
so you can hear the motor going, but you get no window movement
Whats up with RDX owners?
The motor is included and installation takes maybe 30 minutes tops.
Especially one that has shitty reinforcements. The cable holder on the track is a bad design.
It is reinforced by metal, but the tab is only on one side and easily bent after years of use, which is why the plastic ends up breaking.
xsilverhawkx
09-28-2015 06:51 PM
AcuraKidd
09-25-2015 11:18 PM
