Who is the fastest auto and stick on this board?
#81
i havent dynoed my car yet, but its def. on this list asap.
but i have the same mods as you i/h/e + P2R spacers and gaskets, coolant bypass, slave check delete, along with neuspeed suspension.
So its not like i have anymore than you or most on here, I just cant seem to get any better times than modded autos, and its not my driving because im getting good 60ft and im shifting correctly, so i dont know...im told i just have too much heat soak because its hot here
#83
#84
did you dyno in 4th or 5th?
i think i will do both too just to be sure
#86
Whats up with RDX owners?
ill be doing it in both. 4th and 5th..broke my flippin intake earlier, so i need to find or make a new one asap, i cant drive around with just the filter on the throttle-body...
#88
I also have the Unichip which is giving me an extra 10-12 HP on the dyno, there were only 30-40 of us who had one custom programmed about 5 years ago...
I have the UR pulleys as well which I didn't see you mention....
My car was also pulling 210 on the dyno stock which is on the high side for an auto, currently I pull 240-245....
#89
This guy isn't on the boards but he was looking for 470 whp. It more than likely blew the engine.
Just search turbo magazine and acura cl in a search engine.
#90
there are guys on here running in the 13's with ease just with the bolt-ons, and 14.3-14.5 stock, so i thought i should be in the same boat, but guess not..
thanks for the info man
#91
Lead Footed
I'll catch you one of these days . . . if I ever get around to doing the 3.5 build you did.
Right now I've hit 14.2 (14.02 corrected) with a the following set up. Note, the Ram-Air wasn't 100% and I needed a fresh tune. My goal is to break in to the 13s with N/A . . . and no 3.5 build either.
02 WDP TLS Black Interior w/ Black Grill Inserts & Cleared Headlights
1/4mile 14.20 @ 96.95MPH (14.02 @ 98.10 Density Altitude Corrected);
(45-70mph test - 3.5 secs) 17x7 Konig Appeals SMF – 18.2lbs each
P225/45ZR-17 Sumitomo HRT AS P01- (G-Force T/A drag radials for track)
CT Icebox, Custom RamAir, CT Sways & Springs, Tokico Illumina Struts,
SP Performance Diamond Slotted Rotors, Hawk HPS brake pads, SS brake lines,
SPC adjustable front ball joints and rear control arms.
3nd Gen Innovative Motor Mounts – Front (w/black bushings) & Side Only
Bored out Intake & TBs, Mugen Cooling & Thermoblok Mods
Ceramic Coated XS Headers & Magnaflo Hiflow CAT, Custom 2.5”
CAT Back exhaust with Vibrant 1145 Mufflers and custom 2 ¼” tip inserts
Tranny #4 Installed 3/2011
Ruf
Ruf
#94
Lead Footed
was this SC or turboed ?? i am assuming to make so much TQ u wud need that much boost which i dont c possible unless some extensive cooling mods at the intake ( nitros) Big aftercooler ??
even allmotor with is alloutturbo and all that power struggled breaking into the high 12s
Ruf
ExcelerateRep
10-14-2015 08:20 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Joe Avesyan
09-29-2015 03:57 PM
