Where to locate CDD
You know enough to call it CDD, but can't find it in the info sticky ??
A search for dampening would have gotten you the answer real quick:
There's no need to double clutch synchronized manual transmissions
Originally Posted by greenie
6spd mods - clutch dampening device bypass, shifter cable bushings:
https://acurazine.com/forums/showthread.php?t=183560
https://acurazine.com/forums/showthread.php?t=184271
There is when my 3rd gear grinds, while waiting for my clutch to go out, if I double-clutch the tranny before I go into 3rd, it lines up the gears correctly, and does not grind as it goes in, or much less so, than simply putting the car into gear.
GreenMonster, I looked through all those threads, but I still cannot locate the actual place in the car. The diagram shows where it would be in relation to the rest of the system, I don't know where the system itself is.
Ah... syncro died on 3rd gear... that explains the need to double clutch...
Zeta posted a link to the part diagram... just follow the clutch pedal (not pictured) down to the clutch cly. (#7) and follow the hose (#15)... CDD is #23.
MetalGearTypeS
08-29-2016 08:28 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
