where do i get the oil changer
registered pw
someone here posted a pic once but i can't find it. its the one where you don't have to loosten the bolt from the oil pan. i think someone says they are like 60$
any help is appreciated.
and can you use them on other makes
Doin' da crack shuffle
pnuematic one.....
http://www.griotsgarage.com/catalog....2050&SKU=10186
Hand one...
http://www.griotsgarage.com/catalog.jsp?&SKU=10122
Hand one...
registered pw
the units look different. do they work separately.
i guess the way it looks the hand one well thats self explanitory. the pnuematic one, since it looks different do you need the hand one also for the reserviour. just an observation
Originally posted by htown
How do you know when all 5 quarts are out of the car? Is there a place to measure?
I have never had a problem (only used it twice though) so far. My Isuzu Trooper (winter unit) has more the 5 quarts so I had to stop the suction, (by pressing a relieve valve), empty to tank, and then suck the remaining oil out. This one has a nice handle and spout to pour the used oil into other containers (like Gallon jugs or Liquid Laundry jugs or Windshield Washer Jugs...)
Re: where do i get the oil changer
registered pw
it'll work for all of our cars. i just want to change my oil myself like i used to,we rent and i have a shed/garage where the car barely fits in and i don't wanna do it on the street, and crawl under teh car
stejus, do you have the one that red-cl posted or is yours from the marine shop?
Adventurist.
I have the exact same one stejus has.
These pumps will NOT work on dry sump cars (Porsche), but we have nothing to worry about.
Change you oil with no mess and daily clothes is why I bought this system. Plus it takes only a few minutes.
so besides the benefit of the mess factor and the little amount of effort, does this thing remove more oil than the traditional way? you gotta get under the car to change the oil filter anyway, right?
The biggest benefit is you don’t get all dirty, it’s a simply clean up process, you don’t risk stripping the drain plug and you don’t risk tightening the drain plug too tight and cracking the washer.
Spectacular Aroma About
Here's where I got my Oil-Boy: http://www.allaboutboating.com/store...oductID=259057
It was about the cheapest I could find. If you have a marine supply near by they may have it also.
registered pw
cheapest i found so far, i just need to find the shipping charges
http://www.boatersworld.com/webapp/w...atalogId=10051
I bought mine for $94.95 at www.performanceproducts.com.
Unfortunately, my C32 takes about 8 quarts of oil so I needed a larger one. Here's a link: http://performanceproducts.com/Produ...producttype=10
Received 1,080 Likes
For those that use the extractor, do you ever change the crush washer on the oil plug? I realize we're not removing the drain plug, but at some point would the washer start to leak from not being replaced? It's gotta lose it's holding power after a while.
you figure that washer is prob not metal, so it will act like a gasket. and shouldnt leak
Adventurist.
Originally posted by madj80
Is everyone forgetting about the oil filter? You still have to get under the car to change that!!!
Back to Four Doors
Originally Posted by dallison
thanks that reminds me to go shopping on the net for one
Where is my super sauce?
Originally Posted by stejus
There's a list of cars this will not work on. Where ever you purchase this from (there are a number of sites), you should be able to find the list of cars it will not work on. There are not that many.
I use a Griot's pneumatic model and think it's awesome.
I did attempt removal from above with the Subaru, and true enough, I had 2 quarts or so left behind. Damn baffle.
And to NSXNEXT's question -- I've only changed the crush washer on my CL once. As long as you don't remove the drain bolt you don't have to change the washer. As the oil pan isn't a moving part, once torqued up correctly, the bolt and washer shouldn't move/loosen.
registered pw
i fianlly used the oil boy and it worked very well. it took about 10-15 min for all of the oil to be sucked out. it didnt really take much to figure the thing out. it is highly recomended and worked on the accord and rl. and i found out that both cars use the same oil filter
