where can I get new driving lamps?
one of my driving lamps is completely busted and the other cracked pretty bad. I'd like to replace them. anyone know of a site I can get them @? I saw a site that had them for around $45 each. but I didn't save the site. also. I would like to put piaa yellow bulbs there. what size piaa yellow bulbs can go in the driving lamps. thanks guys
Awsome. Thanks. I found the link to buy the parts.
But now what about what size bulb to put in the driving lamps?
I want the piaa yellow bulb.
I did s earch but got conflicting bulb #'s from people.
Can someone just set me straight an the bulb?
the bulbs are PIAA 19224 for white ones 19173 for the yellow ones or you can get the Polarg M6 bulbs i have the 19224 the bulb is colored blue but it shines a pretty bright white light it matches the headlights a lot better and i like it quite a bit you can get them off ebay pretty cheap i got mine from autozone a while back
Just tried to buy a set of these from 704 Motors (formerly c-c-c.net) and they refunded my money. They said Acura is out of stock and couldn't find them anywhere else.
I might just try to do a custom hid install in place of the running lamps. has Anyone on here done that.
Gonna cost to catch up
These are kinda hard to find, but if you do, I have a set of PIAA 19224 bulbs ill sell you.. They work fine, just replaced them for the 19173 yellow bulbs
02 SSM CL-S
Originally Posted by fuzzy02CLS
Those are high watt bulbs however you may burn your housings. The correct replacement is the 5W 194 bulb
Has there been alot of problems with this? I just got a 02 CLS and was thinking I would change the bulbs also.....
snorf
11-04-2019 06:44 AM
