Wheel hop cure part II
Spectacular Aroma About
Hey Guys,
Well I ordered a set of OEM radius rod bushings from acuraautomotiveparts.org. They got here today. I had to re-order because they have a 30 dollar minimum. Good service. Anyhow, The stock bushings are totally hollow!! I'm going to fill them with the urethane and see how that works. I'm a little leary of using solid urethane bushungs there because I've heard that urethane will eventually change shape if it is compressed constantly. These bushings are extreemly soft. The outer lip that rests on the crossmember is only about 1/4 inch thick. The rest of it is hollow. I also got another set of collars that go inside the bushings so I could shorten them and provide a little more preload on the bushings. SHould I shorten the collars or try it without? Just filling the bushings would make this a very easy and almost free mod to cure wheel hop if it works. I hope that stuff (windo-weld) didn't dry out already. I have a bunch left.
Here is a picture to clarify what I'm talking about. The bushings are #10 and 11. The collars are #14.
Originally posted by ModAddict
If possible I would try with the stock size collars, and go from there. If you do need to preload them, you want the minimum prelaod neccessary.
Holy crap, Chad is finally ironing this out...
I think it will help but not solve the issue... We need a ANTI-WHEEL HOP Brace/bar.
Report back
Smitty
Report back
Smitty
Report back
Smitty
Report back
Smitty
Well I put the bushings in. Still wheel hops. Kind of a dud. The hole in the subframe is kind of big so I think the bushing is still resting on the rubber part so I'm not getting much benefit out of the urethane. I went to the Hardware store to get some washers but I didn't have the bushing with me so I couldn't decide exactly what to get. I also found a really nice kitchen faucet for $25 so I made that my afternoon project. One nice side effect is that the front end lost a lot of it's clunkiness it's had since installing the Konis. It also feels tighter in the turns. I'll get some washers and give that a try. Don't know if I'll do it today though.
