Wheel Alignment w/ springs question
Moderator Alumnus
I was gonna do my wheel alignment done at Sears for $59 but when I told him i had the car lowered the dude said the car is aligned only to factory spec. Should I do the wheel alignment anyway, or should I have it done at a place that would actually factor in the cars' drop into the alignment, if that even makes a difference. Sears also said they could possibly match the alignment if I provided Comptechs springs' measurements for the springs... did that come in the kit? what should i do? anyone know where to get an alignment in northern jersey?
alignment specs do not change when you lower your car. with comptech springs it should be no problem, they should just align as usual.
Moderator Alumnus
if thats the case, i'll just get it done at sears today. how often should i rotate the tires? i'm at about 3k miles on these new tires. mind you, thats 3k miles with wheels that have never been aligned
have them rotated before the alignment. then rotate every 5-7K.
Originally posted by Red Rider
Not bad for a guy who has procrastinator in his sig.
divac
08-29-2018 10:13 AM
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
