wheel alignment @ Honda dealer?
Is it OK if I do my wheel alignment at Honda dealer? Its like $50 cheaper. I'd suspect they have the same equipment anyway. they said they would do it for acura.
what do you think?
what do you think?
I got my alternator pulley belt tensioner replaced at a Honda dealereship. The same part was 75 at Honda and 115 at Acura Dealership. With the difference in rates per hour I bet it was at least $50-60 cheaper for the fix at Honda. I would do it again since I have a Honda dealer w/i a mile and the Acura dealer is 80 miles away. I'll use the Acura dealer only for tranny problems from now on because of the tranny warranty extension. I would use Honda for the alignment if cheaper.
Originally Posted by Dan
I would look for a local independent that does alignments, ther are almost always better and cheaper. ![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
BUY MY CL - see garage!
well, my friend went to NTB and they really fuked up alignment on his maxima. he had to re-do it. That place did not even have correct specs. for his car.
honda should be able to do the alignment just as well as acura though
if you need alignment, might as well drop it first
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
acura, aligment, aligner, alignment, auto, cheaper, dealer, dealership, dealerships, honda, hondadealer, independent, redo, wheel, worth
