What's Left To Gain
Old Jul 16, 2007 | 08:39 PM
krisdlm's Avatar
Lives On BOOST
What's Left To Gain
I've only got a couple more things left to add to my car (coils, sways, thermo's), but is there any more power or lost power to gain w/out a s/c or turbo? Maybe if there's no more mods to be made that would be a good sign so I can start saving again.
Old Jul 16, 2007 | 09:45 PM
nbennettksu's Avatar
i heart latin chicks
you done mugen cooling yet?
Old Jul 16, 2007 | 09:50 PM
krisdlm's Avatar
Lives On BOOST
nope, but from what I've heard it's not that important. Thinjim said that when he put his turbo on, his temp went up about one tick mark, just making it hotter, but when he put the stat on, it lowered it about one tick mark, basically keeping it the same as before the turbo. But I'm not running any fi, so would I even need it?
Old Jul 16, 2007 | 09:53 PM
probably not I'm not FI yet either...
I thought thinjim said he rewired his fan to come on at different times?
Old Jul 16, 2007 | 10:39 PM
krisdlm's Avatar
Lives On BOOST
dunno, he might have
Old Jul 16, 2007 | 11:02 PM
RYANGP's Avatar
Not a doctor
high flow cat, performance chip?
also removing the vsa may net you a couple hp's from what i've read
other than that i can't think of anything else you could do staing n/a
Old Jul 16, 2007 | 11:32 PM
SuperTrooper169's Avatar
In the Mid-South meow
Throttle body coolant bypass. Though I didn't really feel any gains it makes sense that the air is cooler without coolant running through there. Plus it costs like a dollar to do.
Old Jul 16, 2007 | 11:37 PM
BigLizard's Avatar
Moderator Alumnus
The coolant temps are very low with all the cooling mods on...check it out.
Here are the numbers when my tranny took a dump pulled from my OBD II scanner tool.
Throttle Position: 23.9%
Engine RPM: 2092
Load Value: 70.9%
MAP Sensor: 72 KPA
Coolant Temp: 163 degrees F
Intake air temp: 82 degrees F
Short term fuel Trim 1: 0.0%
Long term fuel Trim 1: 3.1%
Short term fuel Trim 3: Negative -100.6%
Long term fuel Trim 3: Same as above
Vehicle speed: 66 MPH
Fuel System 1: Closed
Old Jul 17, 2007 | 12:45 PM
krisdlm's Avatar
Lives On BOOST
I wish the unichip was compatible w/ 6spds. Would a high flow cat make a diff? Aren't there risks in removing the vsa?
Old Jul 17, 2007 | 01:34 PM
TCM 01 CL-S's Avatar
Uses turn signals in my
The UR accessories pullies? They don't add much, but when your trying to squeez out all the power you can...
Old Jul 17, 2007 | 01:53 PM
JBlueCLS6's Avatar
I don't think a High flow Cat would net much gains and If I'm not mistaken, Manuals don't have VSA only automatics.
Old Jul 17, 2007 | 03:20 PM
ThinJim's Avatar
I'd start saving. I also will provide a payment plan for the turbo kit. When someone gets to certain benchmarks on payment, I will ship portions of the kit.
The cooling mods work, but as for making more power, nahhhh. It would help with longivity more than anything. With FI there's obviously more heat and the cooling mod helps bring that down.
I wired up the fan to move air across the stove and help bring down under hood temps. It still came on when the switch told it, but I also hard wired it to have more control.
Old Jul 17, 2007 | 05:41 PM
CLsuperhero's Avatar
Go on the bottle or build up a 3.5 if you wanna stay NA
Old Jul 17, 2007 | 05:56 PM
krisdlm's Avatar
Lives On BOOST
I want your turbo soo bad, but I have to think about the bigger picture, and since this is the only car I drive (esp. commuting), I have to think realistically. Someone brave enough and who has the balls will eventually get it and props to whoever it may be.
Old Jul 17, 2007 | 05:57 PM
krisdlm's Avatar
Lives On BOOST
didn't a member do that? How hard would that be?
Old Jul 17, 2007 | 05:58 PM
CleanCL did, he may still be tweeking it...
Old Jul 17, 2007 | 07:33 PM
RYANGP's Avatar
Not a doctor
you're totally right i missed the 6SPD in his sig
Old Jul 18, 2007 | 09:37 AM
ThinJim's Avatar
Having another commuter is a must, especially when doing the install as it's not going in in one day.
Old Jul 18, 2007 | 10:03 AM
thevikas87's Avatar
Your mom is in
god i wish i was at your point in my car modding....but then again i've only had the car like 3 weeks...and hell, the whole point of modding a car is to have fun while doing it and learning some things...hah i gotta get a job
Old Jul 26, 2007 | 07:37 PM
krisdlm's Avatar
Lives On BOOST
that's where the paychecks go!
chasingthecool
Mar 9, 2017 05:16 PM
LoneRonin
Jan 4, 2016 01:03 AM
hashbrown
Sep 29, 2015 12:13 PM
rhdune16
Sep 28, 2015 11:31 AM
ripit
Sep 26, 2015 06:19 PM
