Whats the dot matrix for?
ok so i was wondering why they have the dot matrix in the rear window?
also why is there a little portion of it on the front windshield around the rear view mirror?
sidemarker
sidemarker
Beware of leakage
Originally Posted by Chaptorial
Whatever it is it blows. Makes tinting all the more harder on our car.
It's gone on the 04 TL and i was glad to see it go.![Wave](https://acurazine.com/forums/images/smilies/wave.gif)
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
Liquid Ice
Originally Posted by scalbert
I beleive that the radio antenna in the rear window. The front may be to balance it out.
One of them is definitely an antenna for the radio though. Ever notice how we don't have an antenna anywhere else? No more of those powered antennas that go down into the car when the radio is off but inevitably break (with my luck always in the down position) after a few years?
BTW- A good tinter should be able to tint over the dot matrix with no problem. Mine came out looking fine.
Houses Won't Depreciate?
Originally Posted by proaudio22
From what I've seen in a bunch of cars, the center part is to catch the sun from blinding you when you look up at the rearview.
I had my windows tinted yesterday and they automatically put black vinyl over the dots. When I asked, they said that leaving it w/ just tint, the dots turn silver, like the ring around the side windows.
So...do you guys think that I should have them remove the strip, leaving a wide silverish section? Does it look that bad? Or am I better off leaving the black vinyl on? (They won't charge extra if I have them remove the vinyl) The installer was pretty adament that I would "hate it" if he removed the vinyl.
Thanks!
Thanks!
CLS 6MT Navi
This is the first I've ever heard mention of the dot matrix being an antenna? interesting idea tho. I always understood it just to be a sunshield. I always thought the antenna is in the glass near the defroster just like on other Hondas with no stick antenna.
The dots can not be tinted over as well as glass, but I don't think I'd like a vinyl blackout on the window either. My tint shop said the matrix can be sanded down to make the tint material stick better. I heard the matrix is made out of teflon.
As far as turning silver? never happened on either of my 6 speeds.
Doin' da crack shuffle
There's metal underneath the black paint in the matrix. Sanding will only cause you to have rust spots under your tint.
Dragging knees in
Umm, dude, dot matrix is not an antenna. The antennae on our cars are built into the rear window.
Dot matrix is a type of tint. The dots expand under heat and sunlight, thus blocking the sun more effectively. When it's cold, they shrink. That's why it's a pain in the ass to tint over.
The DOT matrix is not an antenna. The antenna are the parts that are running up & down the back window. Not side to side. The front is also not an antenna. I have been told the dot matrix is to reduce glare. If you look at it from the outside it looks like a tint strip. Just like the regular tint strip at the top of the windshield. Except the martix is there to help reduce glare even more by giving the light a souce of reflection from the dots.
Ok, where is it in the rear window?? Not the defroster lines so the only item left is the metal grate.
Top of rear window.
Honkey
FYI, the reason I didn't tint my windows for 3 years was because I didn't want that dot matrix part to look bad. I found a tinter out here who did mine absolutely perfect. If anyone in AZ wants theirs to look perfect, PM me.
-Aaron
-Aaron
Yes, that happened to me twice ALTHOUGH the dots were never sanded. What a pain in the ass.
This last time they just replaced the dotted area with 3% tint, so if for any reason it rusts again, it will be difficult to see it.
Pics before and after
HELLLLLLOOOOOO NURSE!!!!!
The dot matrix on the from is to act as a sun shade for those annoying times when the sun finds the one place where the shades cannot go. The ones on the rear prevent neck burn on untinted cars as well as protect leather. VW just has pop out shades right behind rearview mirror for that particular spot
Health's Angels
1 Post
Originally Posted by Chopper
Black Vinyl strip will cure all. Thats what I had my tinters do ![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
Health's Angels
1 Post
http://www.hhp.ufl.edu/keepingfit/ARTICLE/Cars.htm
Audi S4 driver
Originally Posted by blader
The antenna are the two vertical lines in the back window, all the horizontal lines are the defroster lines. i'm 99% sure...
You can tell by closely looking at the lines and their connections. They’re the only two that aren’t connected to the others by vertical lines.
It’s been a while since I really looked at it, but I think I’m correct.
I checked mine after work today.
There are THREE horizontal radio antenna lines at the TOP of the glass right in the area of the “dots”.
They are connected with short vertical lines.
Everything below that is defroster element.
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
It's to gradually bring the light in. They do it for your optics so the light comming in isn't instant but gradually come in ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
other then that it's pointless
SidhuSaaB
05-30-2020 12:40 AM
mrkingstonvi
02-22-2016 01:53 PM
