What tire pressure should i run in 235/45 17's ???
i going to be getting the toyo 235/45 17's for my STOCK wheels. what's the best tire pressure i should run?
thanks!
-Silver CL-S, non-navi (shoulda got it!)
-Comptech headers
-Comptech sways
-K&N drop-in filter
-Polarg M6 road lamps
-14% tint all around
-Viper alarm with Car Starter
Check out my sold 98 Honda Prelude:
www.hondaprelude.com/setups/setupsdsply.asp?id=5644&gen=5&orderby=
thanks!
-Comptech headers
-Comptech sways
-K&N drop-in filter
What the car manufacturer suggests.
Eat Safe, Use Condiments
Red CL-S, non-Nav, 35% tint, M6 driving lights, M4 map and door lights
Toyo store in Atlanta said 235/45 would rub, so they wouldn't give the 500 mile test drive option to me. Mike, the moderator, has 235/45s and he has noticed they rub. I got the toyos at 225/45 x17. See my reply to Xephyr on "just got new tires". The way I push my CLS in corners - I like to be in a balanced slide - rubbing would be dangerous. Imagine sliding around a corner at 70 mph and you rub !!! I want no part of that. Be careful is my suggestion.
<font face="Verdana, Arial" size="2">Originally posted by The Colonel:
Toyo store in Atlanta said 235/45 would rub, so they wouldn't give the 500 mile test drive option to me. Mike, the moderator, has 235/45s and he has noticed they rub. I got the toyos at 225/45 x17. See my reply to Xephyr on "just got new tires". The way I push my CLS in corners - I like to be in a balanced slide - rubbing would be dangerous. Imagine sliding around a corner at 70 mph and you rub !!! I want no part of that. Be careful is my suggestion.</font>
The pressure argument is a tough one. Hopefully EricL will chime in and give his 2 cents. I was running at stock 32PSI but EricL runs at 38-39. I have since raised the pressure to 36PSI and have noticed 2 things:
1) Car handles better
2) The tires don't look totally flat anymore
Silver CL-S w/ Navi, Spoiler, Wheel Locks, Trunk Tray, 19169, 9005
Toyo 235/45ZR17-97W* T1-S Proxes on 17X8 SSR Competition Wheels (47.2 lbs lighter than stock wheel+tire setup)
Comptech Sways
G-Tech (Full tank of gas, 60F, VSA off, SS) - 5.94 seconds
V-1 Hardwired
I run 39 PSI on my Toyos (see sig) -- and the tires wear well, don't rub and I like them....
Additional note: I do drive "at the limit" at times, and I have never had a "rub." I'm talking about hauling-ass at ridiculous speeds around corners, and I do inspect the tires CAREFULLY! I also like to drive slowly, so the tires get a mix of wear patterns -- so far the tires look very happy at the 39PSI...
Finally, the section width of the 235/45-17 tires on the 8" wide wheels is noticeably wider than they were on the stock rims!
Silver 2001 CL-S with NAVI
[This message has been edited by EricL (edited 05-08-2001).]
- Mud guards
- Wheel locks
- Toyo T1S 235/45ZR17-97W* Proxies on 17x8" SSR Competition wheels (48lbs less than stock)
- Kevlar/SS Brake lines w/Brembos?
- Comptech headers & sways
- Silver AEM CAI
- 9 coats of Zaino magic
1fatcrxnem1
22
06-01-2018 01:23 AM
nuldabz
09-03-2015 05:49 PM
