what size with drop
what size with drop
need help gettin wheels, just put on eibach sportline springs dropped car 2 inches, can i fit 18"s, stock wheels fit perfect, if so what size tire should i get, also should i get a camber kit for the drop i got???, strut inserts??? little help, thanks
I have the H&R Sport springs (about 1.75" drop f/r) and I run 18's just fine. Just make sure your offset is above +45 or you may have issues. Also you'll have to go with a fairly low profile tire if you dropped 2"... probably 40 or 35. My last rims were +45 and they were OK... my current setup is +48 and they're fine too. Pics and specs in sig....
As for Camber kits... I have the SPC which work great.
225 or 235/40-18 for tires. you may need a rear camber kit.
Poppin them thangs
definitely go with 225/40/18's, 235/40/18's are the better match in comparison to stock tires, but since ur dropped 2", go with the 225's
emailnatec
29
09-28-2018 04:27 PM
ExcelerateRep
10-14-2015 08:20 AM
4drviper
09-23-2015 07:42 PM
