Warranty Help
Warranty Help
my car is 2001 TL and it's time for me to get my brake pads change and aligment. do anybody know is anything consider this is under warranty?? help fast
Re: Warranty Help
i think i needs aligment. it's kinda off balance. so my pads r wear differently. and wat's TSB??
needs an alignment, it's kinda off balance"? Bad alignments are usually indicated by uneven tire wear.. YMMV
so alignment should be free but i gotta pay for pads?? or both??
something witty
i have AEM CAI on my 2001 TL and does that will affect any of my warranty if i take it to the dealer??
came back from the dealer without any service. they told me if my brake pad has more that 50% left then they'll cover with warranty. and also i got brake job at some lil store and they told me that my rear pads r out too and it's my first brake job. isn't rear one takes more time to wear out?? something wrong with my TL if my front and rear pad wear out sametime??
SHIFT_over.so.I.can.see
if the brake pads are worn too much they won't TSB you on the warping. get alignment at firestone. I paid $130 for lifetime alignment.
if you're a DIYer then try doing the brakes yourself. It's not that hard and it only costs about $5 a disc to get them resurfaced at a local auto parts store.
I had my brakes replaced at 13K and again at 30K. When I took my car in for my 30K service, I told them to check the brakes and I did not want the service done till they told me what they were going to do with the brakes. I got a call later in the day and they told me they would replace my brakes again as long as I did the 30K service.
Blown is Best
Not sure with Acura but I've been able to get an alignment out of other car companies within the first year or less than 12000 miles. If the car pulls during that time period, they will check it and for me have aligned as a service adjustment under warranty.
