Warped Rotors Help
Warped Rotors Help
Hey guys, I'm new here. I noticed several of you have had your brakes replaced by the dealership due to the warped rotor problem. I'm pretty sure mine are warped as well. I called my dealership and they said they won't cover it since the brake warranty is only good until 12k miles. Is there any way to get to get it done under warranty seeing as it's a really widespread problem on the CLs? Btw, I have an 03 CL-S. Thanks for the help.
Try another dealership, some have been really good about cutting the rotors and replacing the pads for free under warranty. I had mine done at 30 and replaced the rotors and pads on the front at about 75k.
I'm here in spirit...
My dealer did mine for the second time at 47K. I had to raise a bit of hell to get them to do it but I threw the whole "TSB" thing at them and they covered it.
My Member is Registered
mine have just warped again at 70K miles. Under the TSB and a little strong-arming, my dealer replaced the fronts and shaved the rears at about 45K, replacing all pads as well. They didn't do it without a fight.
Mine warped at 45k. I had to work the dealer a little but they replaced the fronts and shaved the rears, replacing all pads too. Now my front rotors are warped again at 70K. I'm going to have those re-surfaced this time, replacing those pads too. (they need it anyway.)
went to the dealership friday about this. 2003 tl-s with 33k miles. they said they usually only cover the rotors until 20k mi but "they would make an exception for me since rotors shouldn't warp at 33k" I didn't bring up the tsb but I did tell them that I spoke to a mechanic the last time I serviced the car and he told me they were covered.
I just had mine re-surfaced and the brake pads replaced as well. Do a search for TSB 01-017 on here. There are threads with the TSB. If not, send me a PM with your email and I'll pop it over.
Just FYI.
2002 CL-S
33k
They will usually classify it as GoodWill.
You can goto Cush Acura of Escondido and they'll do it with a bit of pushing.
Oh yeah if they resurface the rotors, they should replace the pads. Since it's the pads that are causing the probs.
Good luck!
Just FYI.
2002 CL-S
33k
Good luck!
Ah, no luck with the TSB when calling the dealers. This one dealer (Baranco Acura) told me that there is no TSB and I just got tired of arguing with those idiots. This other dealer (Ed Voyles) told me that TSBs only tell them another way to fix a problem, it doesn't mean they will cover it (as in a recall). I really don't understand why Acura hasn't done a recall on this if it's such a widespread problem. It's simply ridiculous. This one service dude from Ed Voyles tried telling me it's because I drive in Atlanta in stop and go traffic. What about all of the other millions of people that drive and live in Atlanta? This is insane. I can't believe they make up excuses to get out of fixing and covering a known problem.
Also, I need to get 26,500 service and one dealer quoted me $140 for it, but this other dealer told me it's just an oil change. Is this true? If so, why would the first dealer quote $140 for an oil change?
![what](https://acurazine.com/forums/images/smilies/what.gif)
Originally Posted by ajayz
Also, I need to get 26,500 service and one dealer quoted me $140 for it, but this other dealer told me it's just an oil change. Is this true? If so, why would the first dealer quote $140 for an oil change? ![what](https://acurazine.com/forums/images/smilies/what.gif)
the rotors are covered by the "defects in materials or workmanship" clause for 48 months or 50K miles. forget the dealer's bullshit. he' just trying to butt-fuck another customer. if you're within this period they ARE covered. unfortunately the frauds who run the acura dealers refuse to honor warranties. this is called FRAUD.
if you can afford an attorney go that route. it's the easiest on you. hold the owner of the dealership who refused to honor the warranty liable for "death or injury" while you continue to operate the car until the brakes are fixed as a result of wilful breach of warranty. demand compensation for legal expenses BEFORE you permit the car repaired. your attorney will advise you.
if you can't afford an attorney write to the consumer protection division of your state's attorney general's office. this will take significantly longer. demand specific performance in accordance with the new car warranty in writing to the state's attorney general's office. also hold the owner of the dealership criminally & civilly(spelling?) liable IN WRITING for "death or injury" while you continue to operate the car until the brakes are fixed as a result of wilful breach of warranty.
you can find a reference to the "TSB" on NHTSA's web site. it's in there. you may have to search a little, but i found it there a few months ago. i can't remember how much info it gives but it does list the warped rotors as a specific issue that the acura division of american honda has acknowledged & generated a response to NHTSA for. it also can't hurt to list another of acura's dealers who refuse to honor the warranty on the brakes despite the TSB. after enough people complain to NHTSA the TSB response from acura will be rejected and a recall will be enforced.
good luck. you'll need plenty to suffer with the fuckin' frauds at acura.
Both stealerships told me that the TSB was only covered up to 35K... Any know if that is true... And what do I do now?... I have a '01 CL-P (Acura Certi Pre-owned) It has 41k and the rotors are warped :-(
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
