Uninstalling V-AFC wiretap question?
mushroom mushroom
I had the AFC installed at a shop so I don't really know how these work. It looks like there are 2 diffrent types of taps. My question is what is the best way disconnect them?
1st Tap
2nd Tap
Thanks for the help.
1st Tap
2nd Tap
01 3.2 CL-s
first pic, just pull the pink connector off and leave the other part of the tab on unless you want to remove it and then put some electrical tape over the exposed wire..
second pic, disconnect the blue wire from the green/yellow and then find the other end of the green/yellow wire and connect them back.. you may have to solder them but if they installed the connectors right you should be able to just unplug it and then plug the other half of the green/yellow wire back, so it will be connected right
mushroom mushroom
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
navtool.com
09-25-2015 05:15 PM
