# of turn on koni yellows?
Old 12-13-2001 | 10:32 AM
goowakjai's Avatar
Alright, I'm getting my koni yellows installed this coming saturday. I know i'm using the highest perch because i don't want the car any lower, but how about the adjustable ride quality? how many clicks should i do for the front and the back if i want a comfortable ride (like stock), but also a little firmer for performance. I want both. Should i use the factory settings? Thanks for the help.
Old 12-13-2001 | 11:18 AM
BNut's Avatar
S/C'd Accord Coming Soon!
Well the Koni's don't "click" (the Tokica Illuminas have 5 preset adjustments) you just twist a knob.
For the front I recommend 1/4 to 1/3 of a turn and for the rear I recommend a 1/4 turn.
Personally I ride around with my car at 1/2 for front and rear cuz I hate that "mushy" ride. When I do autocross I go full turn back and 3/4's front (helps induce lift throttle oversteer with the comptech sways)
Old 12-13-2001 | 12:13 PM
H@mmerm@n's Avatar
My other car is a 350Z
I have the rears set at 1/2 turn, and usually leave the fronts at 0 turns (maximum softness). I think the combination of Comptech springs and Konis (even at the softest setting) provides a noticeably firmer ride than stock. However, I have found that I do not perceive a difference in firmness or handling ability between no turns and 1 full turn in the front.
Old 12-13-2001 | 04:04 PM
fbazakos's Avatar
on bin laden
During the summer I run at fully tightened.
During the winter I run at half tightened.
SidhuSaaB
05-30-2020 12:40 AM
jblessing
08-08-2018 09:43 PM
navtool.com
31
11-16-2015 08:30 PM
CLsuperhero
09-23-2015 12:53 PM
Quick Reply: # of turn on koni yellows?
